French Import
Where to get small parts not in Katalog?
How/where do I get these small rings that hold the top and bottom halves of the fresh air/heater box? The "Katalog" does not show them as spare parts...
Thanks!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I may have a few. How many do you need? Send me a better pic of the clip.
French Import
I only have 2 out of 6 so I would need 4 if you have them.
They are little open rings that slide (not easily though) over the plastic bumps... I hope this picture will help (thank you FrankC BTW, these are your pics! )
Let me take a look. Mine are from a long hood. Seems like there were some of these and some that had ends that could be squeezed to open them. I had to buy a second box to piece one together.
Gilles how about trying the slip rings that keys are put on. They come in many sizes??
Ernie
----------------------------- Ernie 81 SC |
French Import
Ernie, not a bad idea alas these are pretty small at around 9.5 mm in interior diameter...
I have replaced clips like that by buying coil springs with similar dimension. I was able to get springs at a local hardware store. I cut out a one turn of a spring and then carefully bend it into the shape I needed.
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
I found them. PM me your mailing address and I'll send them today.
I've had good luck at EASY Porsche (salvage yard in CA) with small parts. Good people.
1971 Light Ivory 911T - Gretchen - sold Looking for Engine # 6114097 2010 Cayman |
Try some wire, wrapped around the bumps, then twisted tight.
Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
French Import
![]() I'll try Easy Porsche for other small items.
French Import
I was looking at safety wire as another possibility... Thanks for the suggestion!
French Import
83 911 Production Cab #10
Sometime they are hard to visualized in the catalog.
Retainer 901 571 921 00... Listed on PP as NLA but I had luck before on NLA at the local Porsche dealership. ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
If you cannot find them, these should work.
Bonne Chance ![]()
French Import
![]() A pelican found some in his garage and is mailing them to me. What an awesome site, hey!
French Import
Tom (RD911T) sent me the clips I needed and I installed them today.
Before (temporary solution while dry fitting everything)... ![]() and after... ![]() Thank you Tom!
