Fibreglass gurus needed - rsr bumpers issue
I have a 73 s that is turning into a rsr , the flares are already on the car and i shipped in front and rear rsr bumpers from getty.
both have issues manly that they are short and need to be cut on each side and extend 1-2 inches . what is the best approach to doing this ??
"Funding my obsession one nut at a time" |
measure back a few inches from each end, where the curvature starts to deviate from the flares. Do a vertical cut there. Fasten the loose portions to the end of each flare. Set your main bumper section so its as it will be finally installed.
Now you have to make up the gap on each side. Here is how you can do this: Form a piece of aluminum sheet to fasten to the inside of the two pieces. You are forming a bridge between the large and small parts. This will leave a gap between the fiberglass pieces Fasten the bridge to the parts with some self tapping screws. Make sure your form follows the contours you are after. Next- wax the heck out of the aluminum, leaving the fiberglass exposed. Scuff the fiberglass gel coat with 80 grit paper to remove the outer glossy skin. Feather this back about 3-4 inches on each side of the gap. Get some fiberglass mat. Tear the material to make a plate of "spaghetti". Gloves, well ventilated lit area, eye protection are next. Mix up a hot mix of resin with some of the spaghetti. Using a disposable 1" wide brush, wet the joint area and start dabbing the cloth strands into the gap. Experiment with a small amount at first and let it dry between applications. Keep going till its over full and let dry. Yes, the part should be horizontal on a plastic covered bench: Gravity wins with resin. Sand the outer layers to achieve the fit and shape you are after. Remove the screws holding the aluminum in place. Turn the part over, sand and prep, alcohol to remove any wax residue. Fill in with more spaghetti /resin mix. Test fit, sand to shape, fill in imperfections with bondo and you have a very strong part that matches your flares
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Great write up
Depending in the shape, I've also used aluminum tape and wax paper in place of the aluminum sheet and wax |
Great details cheers , next weekends project
Roland 930 Turbo '81 Too many modifications to list |
one tip that will make your life easier - it's a lot easier of you pre-wet the glass mat. typically i do this on a piece of scrap glass i have. it's a lot easier to lay the wet mat in place and then use the brush to stab it into the area as it sticks when wet.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
good info here
I have used the aluminum tape too and it works well if you're not building up a really large area |
86 911 Targa
I had to cut my rear bumper in to four pieces and had to glue it back together again:My IROC Build
1986 Carrera Targa, SSI and M&K exhaust Last edited by Arnoud911Targa; 02-06-2015 at 12:10 PM.. |
i have done this with smaller holes using masking tape. the tape can be bent to the shape it needs to be.
i put the tape on the front side, then glass the back side. remove tape and glass front side.
cheers , if the area i needed was larger i was going to use form release and make a mould off the outside so to make the insert piece , but thats more work then needed in this case
