Stophos's Avatar
Can you identify these ground cables?
I do not recall where these two grounds go so I am hoping someone can remind me. For perspective the bigger one is about 6 inches long and 2/3 the width of the trans to body ground.
Thanks for your assistance.
- Chris
Old 02-09-2015, 11:37 AM
Fleabit peanut monkey
Bob Kontak's Avatar
On my 81 on the inside of the left rear inner fender there is a ground lug welded in. If I remember, it's about in the middle vertically and closer to the rear seat wall of the car than the rear bumper. Not by a huge amount.
One end of the larger strap attaches there. I believe but could easily be wrong the other end attaches to the aluminum tray that holds the relays and fuses.
1981 911SC Targa
Old 02-09-2015, 11:46 AM
Stophos's Avatar
Bob, Thanks for your response. I have that ground lug in my 69's as well. I believe that the smaller wire was actually on that panel and may very well be the one that goes where you describe rather than the large one. Maybe someone with a 69 will chime in her.
Thanks again,
Chris
Old 02-09-2015, 03:13 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
hi chooch, happy new year.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-09-2015, 03:35 PM
Stophos's Avatar
TUde, You too! Whats happening bump?
Old 02-09-2015, 04:07 PM
pors1968's Avatar
+1 part number 901 612 323 01 panel ground strap.
Old 02-09-2015, 04:48 PM
Classic's Avatar
The small pig tail is for the earth from your electrical panel to the main earth on the left side near the CDI if fitted.
The larger one looks like the earth from the engine case to the back of the alternator
Classic 1969 911T
Old 02-09-2015, 04:50 PM
Stophos's Avatar
Classic, I think you are correct on both.
Thanks - Chris
Old 02-09-2015, 04:55 PM
