-   -   Steve Wong Chip - WOW (http://forums.pelicanparts.com/porsche-911-technical-forum/850815-steve-wong-chip-wow.html)
david482 02-09-2015 07:42 AM
I have a pretty much stock 89 Cab and have been thinking about mods and things i could do relatively easy and in reading through the posts the SW Chip seemed to great great reviews so finally pulled the trigger.
I installed it this weekend, very easy, toughest part is getting to the nuts that hold the Motronic box, long skinny fingers would help (something my had does not have).
Car fired up and immediately seemed to be run smoother as I started driving. Overall responsiveness seems much better and the seat of the pants dyno sure seems like more power.
So far seems like it has really improved the power and pickup especially around 4K RPM.
Driven97 02-09-2015 08:42 AM
I wouldn't say it uncorked a ton of power in my car by seat of the pants, but the idle, part throttle, and lack of 4k dip improvements cannot be overstated. Maybe my favorite money spent on the car.
megerian 02-09-2015 11:16 AM
Same here, easy to install mod, and totally reversible, assuming you keep the stock chip. I love mine.
gliding_serpent 02-09-2015 11:58 AM
Best bang for buck for the 3.2's by far. To get that kind of power benifit for any other mod you need to start adding an extra zero to the price.
archizzzz 02-09-2015 12:52 PM
anyone using a steve wong chip in california?
jlex 02-09-2015 01:06 PM
My '85 was doing a bit of surging between 2m-3m rpm's. Spent a decent amount of time running it down to no avail. Installed the SW chip in the car last year & surging is now gone. Thanks, Steve.
pepebaja 02-09-2015 02:05 PM
I had same question in regards to having SW chip in California and if so, is it a replace with original chip for smog.
cabmandone 02-09-2015 02:17 PM
What power benefit is seen? I have seen a lot of S.O.T.P dynos but no real numbers. Does the fuel mapping change throttle response on the low rpm range where it's really needed? My car is a little "doggy" in the low rpm range but wakes up nicely in the 3500 and up range.
Pstallo 02-09-2015 03:56 PM
I didn't do any pre- post- dyno tests on my Cab when I installed the chip, but it seems to me like the power comes on sooner in the RPM range than it did before the swap. I really like it. That plus the MK premuffler and an MAF really changed the sound and feel of the car when driving it.
They may be small changes, but they're FUN changes, especially when the top is down.
Pstallo 02-09-2015 04:00 PM
BTW, does your 89 Cab have rear shoulder harness seatbelt? I have an 86 and they aren't even a possibility. For the kids' sake, I'm on the lookout for a 911 Cab that does.
jeffbottman 02-09-2015 04:05 PM
Quantitative data: SW chip, M&K premuffler and 1/1 muffler, Dynajet dyno run:
241 HP with very good-looking plot.
Stock HP is 207 I believe. '86 car, pretty high mileage.
Driven97 02-09-2015 05:19 PM
There's lots of dyno charts on the 911chips website.
Like I said though, the full throttle stuff is nice. The low end "dip" goes away, and the power doesn't taper off near redline like the stock map. But the real magic is in the part throttle driving, and the better idle control. Makes the car easier and more responsive to drive even just around town. That doesn't show up on dyno charts.
jlex 02-09-2015 07:23 PM
Originally Posted by pmax (Post 8479038)
Why would a change in mapping fix a surging problem ?
I don't know. Just reporting my experience. Seemed to make it more user-friendly around town at lower speeds as well. Nearly eliminated the "bucking" that I used to have to control by using the clutch more at slow speeds.
Tippy 02-09-2015 08:01 PM
Fuel and timing adjustments. You get into an oscillation that can be tuned out if you know how.
Speed metal 02-09-2015 08:53 PM
I can report some similar results. I installed a SW chip this winter. 93 octane, cat delete chip I believe..
I installed the chip, started the car. Success!! It ran! ;) I then took it for a short run(With the stock CAT still in place)
Idle quality was much better. Also seemed to have more zip over 4KRPM. I was happy enough and parked the car. Last month I finally installed the Cat-Delete pipe I built and waited another month for some decent weather.
Happy to report, it was worth the effort. Better response in damn near all the throttle range.The 3.5K power leaves the stock setup in the dust. Sounds much better too with the new pipe. (Gratuitous pics of said pipe to follow lol!)
Worth the $ for sure.
http://forums.pelicanparts.com/uploa...1423543414.jpg
http://forums.pelicanparts.com/uploa...1423543472.jpg
http://forums.pelicanparts.com/uploa...1423543726.jpg
Pstallo 02-10-2015 05:00 AM
I agree with the surging fix. Before the chip, mine was a surge at idle from about 800-1200 RPMs about once every two seconds. Don't know how it fixed it, but it did and I ain't complainin'.
david482 02-10-2015 05:08 AM
On the seatbelt question my 89 does not have rear shoulder belts only the lap belts.
gliding_serpent 02-10-2015 05:27 AM
That is a complex question for sure. Maybe best to talk to Steve. He has a lot of dyno charts on his website which are worth taking the time to look through.
Here is the jist of it... Steve Wong shared this himself a number of years back.
It is a good summary of expected gains for the average healthy 3.2. Now this is WOT data, so I can not comment on part throttle/lower RPM gains/losses. I know his site says his chips to remap part throttle also... but to what end I can not say, as my car came with one of his chips. Your choice of intake, exhaust, cams, tuning, etc will also play a big part in the lower and higher rpm gains/losses. Generally, the guys that gain bit top end power do at a cost to low and mid range livability. I went SSI as the primary diameter is more optimal for mid range and part throttle applications. YMMV
http://forums.pelicanparts.com/uploa...1423574263.gif
Of note, steve also has dyno data of open airboxes adding maybe 5hp to a stock 3.2 (needs to be chipped tuned however). Gains from the airbox increase as the total output of the engine goes up (i.e. more to gain with a more powerful engine).
The advantage of dyno tuning a car with a chip is that you can use the data to id an unhealthy engine, or unhealthy air/fuel ratios (which can be corrected). That in its own right may fix some running problems.
jlex 02-10-2015 08:25 AM
Wow... beautiful work on that cat delete pipe. You didn't happen to make a spare, did you? ;)
Bleedsblue 02-10-2015 08:56 AM
Actually, I think this does show up in the charts w/ how smooth/linear the curve is. No?
No kidding! Such welds... :eek:
pepebaja 02-11-2015 04:55 AM
sw chip
Anyone with sw chip in ca. pass smog.
Driven97 02-11-2015 07:10 AM
I'm not 100% on this, but pretty sure at WOT (aka dyno chart) the ECU is in open loop. Fuel and timing values are just read off a chart per rpm. Theoretically is the easy part to do, just need good AFM values and a nice knock sensor.
Part throttle should be closed loop. This takes feedback from sensors. Not sure what the 3.2 has sensor wise, but at least the O2 sensor and air flow meter. There's where the work and details are, as you have to make a multi-dimensional map accounting for many variables. That's where things get a lot more complicated, difficult, and time consuming.
Part throttle stuff doesn't show up on a dyno chart, but it does show up every time you don't have your foot to the floor, which is honestly most of the time. WOT peak numbers make sales and grab headlines, but IMHO there's more value in the attention to details. Otherwise we'd all be pining over 707hp SRT Hellcat Challengers.
I drooled a little at that gorgeous piece.
Bleedsblue 02-11-2015 09:25 AM
Yeah, good point, I'm sure the dynos are WOT. Even still, the SW lines are much smoother than stock and other chips.
And wait: you're telling me even a small part of you doesn't fancy a Hellcat? I might go for the Charger myself...
Driven97 02-11-2015 09:47 AM
Hellcats are badass, no doubt. But I see them more as a fake breasted porn star - would rather have for one crazy night than commit to an everyday relationship.
Bleedsblue 02-11-2015 10:20 AM
Haha, well said Matt. I just love a sleeper sedan, but would never trade my little 200hp 911 for anything.
GaryR 02-11-2015 10:30 AM
Either my tuner sucked (which I know he doesn't!) or those are some pretty optimistic dyno numbers floating around unless they are BHP not WHP... My brand new balanced/blueprinted motor, custom EL headers, open pipes, with a custom burned chip I hit a high of 230 WHP on his (Behe Performance) dyno..
Bleedsblue 02-11-2015 10:33 AM
That chart shows BHP numbers, for sure.
pmax 02-11-2015 12:59 PM
Website faq says the mapping's unchanged at "low load" and chip's not recommended for ca emissions.
I don't understand the idle improvements being reported here.
quote:
we leave the low load fuel regions factory so that you will continue to enjoy factory fuel economy and emissions while putting around town, or cruising on the highway.
In a state such as California with very stringent emissions limits, although most cars pass emission testing without problem, swapping back to the stock chip and reinstalling the catalytic converter is recommended ...
db_cooper 02-11-2015 02:08 PM
I think the improved idle is due to the slightly advanced timing at idle..The factory (it has been a long time, so I may be wrong) was something like 5* ATDC..engine warm at about 900 rpm..no load.
The SW chip puts the timing up to about 5*BTDC, warm engine, 900 rpm, no load...The revised timing map helps smooth out idle and the transition to low load take off.
Nine17 02-11-2015 08:46 PM
I've passed California smog every other year since '07. '88 3.2 with SW Chip, open air box, sport 1-out muffler. Love the smooth power.
todd230 02-11-2015 09:53 PM
I sold an 86 with a SW chip that passed no issues. The chip was set up for SSI + dansk 2+2 which were not sold with the car. Original exhaust and cat were reinstalled as was the airbox.
todd230 02-11-2015 09:54 PM
That was 2 years ago..
pepebaja 02-12-2015 04:50 AM
Steve wong
Thanks for input.i guess I have to order a custom 91 octane.have open air box and dansk 2 in 2 out sport. Thanks for help deciding chipping it.
