-   -   trying to change my 1995 993 key head. (http://forums.pelicanparts.com/porsche-911-technical-forum/850977-trying-change-my-1995-993-key-head.html)
scott (guest) 02-10-2015 05:20 AM
trying to change my 1995 993 key head. got a new one w a LED light. much brighter. how do remove/install the metal key?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-10-2015 05:20 AM
I'm pretty sure you split the old key open using a flathead screwdriver. Then remove the key from the plastic body and transfer it over to the new body.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
KNS 02-10-2015 07:23 AM
Once opened there is a little tab on the side which slides into the metal key blade. carefully pry this little tab up and out of its slot to release the metal portion.
