Looking for an oil tank and oil lines for a 2.7S engine?
I'm looking to get a used oil tank and oil lines for a 2.7S part of the process of fitting the engine in my VW type 2 bus, any suggestion please?
Old 02-10-2015, 12:14 PM
Vintage Owner
Jack Stands's Avatar
As I imagine you need to have some lines custom made, I'd suggest getting the adapter that goes from the metric Porsche fittings to an AN-12 size, then you can use the readily available AN fittings to have the lines fabricated. A generic dry sum oil tank from Summit should work if you can't find a used one.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-10-2015, 02:39 PM
Vintage Owner
As I imagine you need to have some lines custom made, I'd suggest getting the adapter that goes from the metric Porsche fittings to an AN-12 size, then you can use the readily available AN fittings to have the lines fabricated. A generic dry sump oil tank from Summit should work if you can't find a used one.
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 02-10-2015, 02:40 PM
Brew Master
cabmandone's Avatar
I'd suggest trying the classified section 911 used parts for sale & wanted. Post there, you'll find out pretty quickly if there's something out there.
Old 02-10-2015, 02:41 PM
Thanks Jack Stands!
Old 02-11-2015, 12:16 AM
Thanks ca manado. I will do that!
Old 02-11-2015, 12:17 AM
