-   -   81SC - need help with rear fuse wiring (http://forums.pelicanparts.com/porsche-911-technical-forum/851204-81sc-need-help-rear-fuse-wiring.html)
Kemo 02-11-2015 01:23 PM
I have an 81 that came without the metal mount that holds the CDI unit, Defroster Fuse, and the engine harness plug. I had to source all the bits and pieces from scratch to put all this together. In any event, Im at the point where I have to wire up the 3 block fuse panel. Can anyone take a look at how this is wired up on a stock setup and hook me up?
http://forums.pelicanparts.com/uploa...1423689614.jpg
the wires I identified are as follows based on the picture and how I was positioned:
Left Side: big red wire and a little red wire
Right Side: big red wire, red with white stripe, red with black stripe, blue with yellow stripe
Thanks!
ghamilton 02-11-2015 02:19 PM
I'll try and remember to pull the cover off my 82 when I get home.
If I can get down my driveway!
Read 70+" snow in last 25 days..
This is before the 24" we got this past Monday.
http://forums.pelicanparts.com/uploa...1423693052.jpg
Kemo 02-11-2015 03:07 PM
OMG!!! hope your heater works!!!
ghamilton 02-11-2015 03:22 PM
Yup, nice and toasty in garage.
Hope this helps.http://forums.pelicanparts.com/uploa...1423696961.jpg
tirwin 02-11-2015 06:23 PM
One of those red wires on the left side of the fuse panel in the picture above is constant power and the other is switched power. I'm pretty sure the top (with the copper bridge to the middle fuse) is constant and the bottom is switched. You'll have to put a voltmeter on them with the car off to figure out which one is which.
chadco 02-11-2015 07:14 PM
1979 rear fuse pic.
Here is mine, it is a 1979 :D
chadco 02-11-2015 07:17 PM
whoops forgot pic:o
http://forums.pelicanparts.com/uploa...1423711008.jpg
Kemo 02-12-2015 06:09 AM
so from the pic, it looks like Big red to top, little red to Bottom on the left side. But the big kicker here is constant vs switched...constant on top.
and it looks like Big Red to the top, red-white stripe middle and the other two bottom...on the right side
does that sound about right?
LM3929 02-13-2015 10:47 AM
In case you didn't see one there should also be a short 6" brown ground wire from that aluminum consul to the ground stud
Lorne M
