-   -   Altitude Control Unit (http://forums.pelicanparts.com/porsche-911-technical-forum/851752-altitude-control-unit.html)
Tcrate 02-14-2015 06:44 PM
Does anyone know what this unit does. I pulled my drivers seat today and noticed this unit underneath. I don't believe it was connected but I am not completely sure whether it was or not. Lets just say when I went to remove the wire connection it either was not connected or the connector was not tight. I believe it should be left disconnected but I am not sure.
Part number is 944 606 151 00 picture attached. http://forums.pelicanparts.com/uploa...1423968205.jpg
DRACO A5OG 02-14-2015 06:59 PM
It adjust mixture on extreme altitude change. If you are not in a mountainous area then I guess you can leave it unplugged???
Tcrate 02-14-2015 07:12 PM
Ok but sounds like plugged or unplugged it should not matter. I do have a different chip than stock in this car would that change anything?
Porsche 2 02-14-2015 07:52 PM
Plug it back in. It is part of the computers input, no downside if plugged in.
Quicksilver 02-15-2015 07:56 AM
It is a simple on off switch that flips at 3500 feet (or somewhere else in the 3K range...).
No reason to disconnect it simply because you aren't apt to remember when you go on that one drive through the mountains.
ischmitz 02-16-2015 02:16 AM
As Wayne said it's a simple switch that closes above a certain altitude to compensate for the lower air density up there.
The DME will lean out the mixture when this switch is closed. However, this is done through software and the switch is read through one of the A/D converter channels. So if the chip maker has enough skills this could have been be disabled with an aftermarket chip. Not that there is a reason for it. Only way to test would be to simulate the switch closed and check that fuel signal changes slightly.
So I'd connect it back after verifying the switch is open while you are close to see level.
Ingo
Chuck.H 02-17-2015 06:21 AM
I had a thought once that maybe this switch could be tested by putting it in a vacuum bag and pulling a slight vacuum? Has anybody tried this, or want to (easily) defeat my atmospheric knowledge?
Chuck.H
'89 TurboLookTarga, 391k miles
