-   -   Setting Boost (http://forums.pelicanparts.com/porsche-911-technical-forum/85219-setting-boost.html)
James_TX 10-24-2002 08:47 AM
Setting Boost
I did a search and didnt see anything about this...
How do you adjust Boost?
Is there a "How-to" anywhere?
juan ruiz 10-24-2002 08:49 AM
Can some one provide me with the instruction manual of a
Greaddy Profec B,Thanks
beepbeep 10-24-2002 10:16 AM
use one of following ideas:
- change wastegate spring (worst way)
- use T-pipe (better)
- use Dave's device (like T-pipe but better)
- use electronic boost controller (best)
Amac 10-24-2002 02:12 PM
So you want to kick it up a little!
Do it the easy way with a 1.0 spring, it's a pretty safe
way to go.
You need to careful with the adjustable stuff for now, you can
play with that later. Too much boost on a stock motor will put
in the crying game fast.
Try the spring, you'll be happy for now.
The dark side awaits!!
"You might a hp junkie if "
You have a boost gage re-set key on your keychain!!
