1969 911E blinker
So I have traced back all the way to headlight switch do these go bad overnight .
I just need direction on testing it before I purchase a new one .
Anyone Familiar with the procedure on testing this?
My problem is when the light is pulled on the fuse blows checked all wiring witch leads me to believe it's the switch itself .. Do they ground out?
Old 02-16-2015, 08:58 PM
Send a message via Skype™ to Porboynz
So with all the wires disconnected from the switch except for the 12V feed it blows a fuse when activated?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-16-2015, 10:25 PM
I will giv it a go and let you know thanks
Old 02-17-2015, 12:13 AM
Send a message via AIM to fintstone
Usually not. Generally it is a hot wire that is shorted to ground in the dash lighting.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-17-2015, 07:29 PM
Don't disconnect the switch. Just leave it off and measure for ground at each pin of the switch. The ones that read as direct grounds are the ones you need to trouble shoot. If you are not sure (low resistance)...look to see if it is a circuit to a light bulb. Remove the bulb and it should go to high resistance.
Old 02-17-2015, 11:10 PM
