Bilstein coil over conversion
I know Elephant and RSR make coil over conversion kits for the 911, but they are quite pricey. Summit racing sells Bilstein coil over sleeve kits as well, for considerably less, has anyone used them?
http://www.summitracing.com/int/search/brand/bilstein/product-line/bilstein-coil-over-sleeve-kits?autoview=SKU |
appears that the difference is the extended upper perch to keep the spring below the shock mount tube
http://forums.pelicanparts.com/porsche-911-technical-forum/681609-looking-coil-over-top-hats.html |
| All times are GMT -8. The time now is 11:29 AM. |
