theiceman's Avatar
Help getting wrist pins out ..
Normaly i dont have an issue with this , but currently i am stumped and frustrated.. thought would give it up for the night rather than continue to work frustrated..
i am dealing with alusils so am trying to leave the pistons and cylinders intact. i slid the cylinders off so i could clear the wrist pin . then i took out the spring clip. the problem is how do i get the wrist pins out .. i have to pull them out rather than push them obviously .
i fashioned a rudimetary slide hammer , but after moving about a quarter they stop dead. i have tied to so far with the same result. maybe i need to fashion a better tool ? these things are just not moving ( i dont want to bend a rod ) . i put a 8 inch bolt through the closed end of a wrench , then through the wrist pin , then onto a washer that just covers the wrist pin at the other side. and then a nut.
i then hit the wrench with a hammer to knock them out . i have tried to so far and both move a little then stop dead.
What am i doing wrong ? or is this generally an arduous task? i dont want to do any damage and replace more than i need to .
If they had been nickies i would have just popped the cylinders off drove them out ... this is frustrating.
i guess worse case i could build a puller like the guy did in the other thread I searched . couldnt find anything else though.
anyone have any tips ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 02-23-2015, 04:50 PM
87 - 911
I struggled with mine, was a fight to get them all out. I fashioned a slide hammer like tool as well.
One thing I didn't try but should have was to warm up the pistons, could try a heat gun or hair dryer.
Just a thought, keep trying they do come out
Old 02-23-2015, 06:07 PM
Project Addicted
I use this from Motion Pro.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 02-24-2015, 04:51 AM
Old wive's tale about needing to leave the piston/rings in the exact same place w/alusils. Just take the cylinder off and do it the easy way. No guarantee that the rings are even in the proper position. I never had any issues.
206 637 4071
Old 02-24-2015, 05:15 AM
theiceman's Avatar
ohh i like that tool ...
hmm thanks John , I was just going by the dempsy book but in my searches last night i did see comments to the same effect as yours.
Old 02-24-2015, 05:22 AM
kodioneill's Avatar
Heat the dome of the piston with a mapp torch the pin will slide out with finger pressure.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-24-2015, 05:43 AM
theiceman's Avatar
even with the piston still in the cylinder like what i was attempting ? or just removing the cylinder as John suggested ?
Old 02-24-2015, 05:45 AM
douglas bray's Avatar
I like it...
Deluxe Piston Pin Tool | Motion Pro
Old 02-24-2015, 06:21 AM
theiceman's Avatar
Originally Posted by douglas bray View Post
yeah me too Doug ...
amazon.com $40 USD or so
Amazon.ca $220 CAD
see what i have to put up with ? Think i'll just go make my own
Old 02-24-2015, 07:03 AM
Ice, did you try taking a heat gun to the piston? I did that on install and they slid in.
John
"Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage
Old 02-24-2015, 07:40 AM
