gearbox chatter
I have some gearbox chatter at low rpm. It mostly goes away when I hold onto the gearshift lever or put pressure on it one way or another. What do you think that is attributable to?
Sheldon
Old 02-21-2015, 06:54 PM
Oh Haha's Avatar
What year 911?
Pacific Blue
Wayne
Old 02-21-2015, 07:08 PM
1987.
Right, sorry, 3.2 1987.
SMS
Old 02-21-2015, 07:18 PM
Shift linkage vibrations.
Jon B.
Vista, CA
Old 02-21-2015, 11:32 PM
What's your idle speed?
We have a couple of cars fitted with light flywheels (3.0SC) an Aluminium clutches.
At 800 rpm idle there is a slight shake that causes some chatter from the transmission with the box in neutral.
At 960 rpm it does away, its is also fine in gear and under load.
Old 02-22-2015, 02:00 AM
I have gear chatter in my 1966 TR4 and I believe it is from a warn out gear box.
Old 02-22-2015, 04:28 AM
Oh Haha's Avatar
We just discussed this issue a few weeks ago. It MAY be the G50 chatter which is normal.
Transmission 'chatter' - time for a rebuild?
Pacific Blue
Wayne
Old 02-22-2015, 06:28 AM
My 915 in 82SC is pretty noisy specifically if you load it up in a higher gear at low rpm. I figured bearing noise and I was up for a rebuild at some point. Maybe it's normal ...
Old 02-22-2015, 05:57 PM
