Back light switch Sportomatic
Have problems with intermittent function of Back (reversing) light.
Sportomatic switch has 4 contacts but manual only 2. What are the extra contacts on the sporto switch? ![]() ![]() Thanks Graham ![]()
Hi Graham,
according to electric diagrams there are 2 terminal 50's and 2 terminal 15's 50 terminals are from Ignition and to Starter motor - default position is on 15 terminals are from fuse S11 to Reverse Lights - default position is off when you shift into reverse lights on terminal 15 are on and circuit on terminal 50 is off well that's how i interpret the diagram cheers Shane
Shane 1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500 1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158 Last edited by rodoredas; 02-23-2015 at 03:42 AM.. |
Thanks Shane.
Have you a circuit diagram for the 911L (1968) Sportomatic? If so, any chance you can post it i never seem to have found one. Best wishes Graham |
Hi again,
Have found circuit elsewhere on Forum now. In fact I had it in my "Driving with Sportomatic" booklet and Porsche Workshop Manual if I'd looked more closely. I also find the starter will occasionally not always turn over until the shift lever is moved between various gear positions. I suspect this may be one of the two switches. I know where the Backup light switch is. Where is the Bypass switch? Thanks in anticipation Graham |
It has been many years since I've driven my Sporto, but I seem to recall it having a neutral lockout switch (meaning it won't start unless it is in neutral). Also the microswitch on the shifter can be a bit touchy.
John Thompson Eugene, Oregon |
Hi Graham
I doubt it but try this, Google "porsche 911 workshop manual pdf" link to the Early911nzdownloads site, it seems to have heaps of stuff for the early models cheers
Shane 1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500 1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158 |
