Eliminate Front condensor with 993 unit?
I added a turbo and a full bay IC to my 85 3.2 targa. In doing so I lost my rear mount condenser and thus my AC. I've gone ahead and installed a condenser from a 993 in the rear fender well with a spal fan. As this is the only condenser used in the 993 can I eliminate the poor little front mount cooler from my previous system without significantly effecting performance? it would certainly simplify the plumbing.http://forums.pelicanparts.com/uploa...1424810526.jpg
http://forums.pelicanparts.com/uploa...1424810555.jpg |
If you have not updated your compressor, I would stick with the front condenser. You should also consider a large centre vent under the dash in place of the puny butterfly one.
Hope this helps. Good luck. Johan |
the more the better, leave it
| All times are GMT -8. The time now is 07:22 PM. |
