lespaul's Avatar
Rubber Flooring Option - has anyone tried this?
I hate carpet. I am thinking of deleting all carpet and the back seats from my 78 SC and installing this rubber flooring over all the floor surfaces and resulting back seat shelf.
http://www.amazon.com/Diamond-Plate-Rubber-Flooring-Rolls/dp/B00E7KYKSC
That, plus aluminum floor boards and pedal set would look good, and make it easy to maintain and keep clean. My instincts say just copy the pattern of the existing carpet and install with some 3M spray glue.
Has anyone else tried this? If so, can you post pics and describe how you approached this?
Brad
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 02-26-2015, 09:11 AM
Troll Hunter
Brad,
I'd check the weight against RS type carpeting. Plus, it's 1/4 inch thick? Pretty thick stuff!
Nick
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 02-26-2015, 09:22 AM
lespaul's Avatar
Good point. I think it is 1/8 inch/3 mm thick though.
Brad
Old 02-26-2015, 09:26 AM
lespaul's Avatar
Just did some checking. The 1/8 flooring is 0.67 lb/sq ft. I am guessing that 6 ft x 8 ft would cover the floor and back shelf. That is 48 sq. ft. or 32 lbs. I don't know how that compares to carpet.
Brad
Old 02-26-2015, 09:32 AM
gshiwota's Avatar
I like the idea as this should quiet your car down considerably. I remember years ago a friend of mine did this in their wife's 50's Mercedes 220 Cab using rubber tiles they were throwing away from their gym. He said the car was quieter and "felt more solid" than a new Mercedes S-Class.
However I'd be sure to check to see if the rubber smells like rubber. It'd suck if your car smelled like the inside of a tire.
Old 02-26-2015, 10:11 AM
Why not bed liner? Many of the off-roaders spray the interior of jeeps and similar. Easy to clean 😉
Old 02-26-2015, 10:26 AM
El Duderino
tirwin's Avatar
Have you considered the Rubbertite floor mats by Lloyds? Pelican sells them.
DriveWerks.com - Custom Floor, Trunk and Cargo Mats - Floor Mat Materials - RubberTite
I have thought about a set to throw in for daily driving and coming home from the track.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 02-26-2015, 10:27 AM
lespaul's Avatar
I thought about BedLiner, but that is a permanent bond that I think would devalue the car.
I have looked at the Lloyds mats and they may be a nice alternative. However, I like the idea of covering all the floor surfaces with one seamless covering that will prevent water from getting under the mats and, if some floor is exposed I think it will be loud. A seamless rubber floor covering -- as is found in my Honda Element, is very easy to maintain and should even be good for the track as compared to carpet.
BTW - my Honda Element does not have a rubbery tire smell at all.
https://www.skidmore.edu/~pdwyer/e/images/seat_track03.jpg
https://sp.yimg.com/ib/th?id=HN.608037502665097722&pid=15.1&P=0
Brad
Old 02-26-2015, 10:46 AM
86 911 Targa
I've used it for my build. Great stuff easy to work with, you can cut it with a pair scissors in like 30 minutes or less. But make sure you take the PVC version not the rubber stuff. 15 minutes in the sun and the rubber will make your car smell like you are inside of one of your tires. PVC is odorless and has the same texture.
1986 Carrera Targa, SSI and M&K exhaust
Old 02-26-2015, 12:12 PM
lespaul's Avatar
Arnoud,
Awesome. Great tip on the vinyl.
I am going to try this and even wrap the vinyl up over the hump and rear seat shelf. Going to try to do it with as few pieces as possible.
Did you use anything to adhere the vinyl to the floor?
Brad
Brad
Old 02-26-2015, 12:18 PM
86 911 Targa
No I just used it for floor mats. You can see in the picture that the mats are still a bit curly but they will straighten out pretty quick. I didn’t use any adhesive so I can take them out with ease. For the other parts I used RS carpet to keep light.
My Build
Old 02-26-2015, 12:23 PM
Troll Hunter
An entire RS carpet kit for front and rear is about 20 lbs. Your estimate for the rear alone is 32.
Sounds heavy.
1988 FJ62 Blue/Gray
2020 M2 CS
Old 02-26-2015, 12:30 PM
86 911 Targa
Sure it is heave compared to RS carpet, but they are not any heavier than the original floor mats.
Old 02-26-2015, 12:42 PM
Vintage Owner
Jack Stands's Avatar
Just wish that Weathertech made the molded floor mats for the early 911s! They are great in our daily drivers.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-26-2015, 02:27 PM
I've used 'rubber' pool-liner in the frunk and under carpet. It does a great job in quietening, removing draughts, helping AC etc... Putting it down without adhesive also means its easily removable.
1982 911SC Wine Red Metallic
OMG I love this car!
Old 02-26-2015, 03:04 PM
non-whiner
mreid's Avatar
I don't think you will be happy trying to cover the rear seat area. The carpet kits require quite a bit of stretching and trimming to fit and look good. That matting does not stretch and will drive you crazy.
"Too much is just enough."
Old 02-26-2015, 03:07 PM
onboost's Avatar
Brad
Not exactly a new idea guys. The factory offered rubber floor mats back in the long hood days, 69-73 I think. They were an option if I recall.
They were ribbed on the top surface and had leather straps riveted to them to slip thru the little loom that the floor boards slipped onto. However, I think they were just driver and passenger side front only. I still have a set for my early S.
Also, I believe someone was making repos of these and may have offered them in 4 place sets.
RGruppe #180
Old 02-26-2015, 05:20 PM
MConn's Avatar
I have a set of the Lloyd's RubberTite mats in my DD. they smelled for 3 months and are heavy, but they do protect the carpet.
I like the look of the diamond PVC for the floor. If it would mold to shape (heat gun ?) it may be worth the weight.
Mike
The more I learn, the less I know.
Old 02-26-2015, 09:02 PM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Cut to size and then weigh down all the corners with dumbbells or whatever you have that is heavy on all the curves and corners. Leaving in the hot sun would help. Once you have the general shape holding I would put industrial velcro at the corners to keep them from curling or sliding. Velcro adhesive would come off with some goo gone if you decided you didn't like it.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 02-27-2015, 06:43 AM
Wer bremst verliert
JohnJL's Avatar
That stuff looks good in my fj40. Not so much in a 911, in my opinion.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-27-2015, 07:23 AM
