-   -   Turn Signals Fuse (http://forums.pelicanparts.com/porsche-911-technical-forum/853485-turn-signals-fuse.html)
PRE-H20 02-25-2015 01:55 PM
Turn Signals Fuse
Can anyone show me where the turn signal fuse is on a 1974 911?
picture would be the best.........
my turn signals stop working so i figured i would start at the fuse...... just need to locate it.
fuse box is driver side under the hood.
thanks in advance.
timmy2 02-25-2015 08:24 PM
Relay for the flasher is fed by fuse 17.
PRE-H20 02-25-2015 08:39 PM
You wouldn't happen to have a picture of our fuse box would you?
timmy2 02-25-2015 10:06 PM
There are a lot of fuse box photos in this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/772278-cheap-easy-ato-fuse-block-installation.html
Start by seeing if you can download the '74 schematic from here.
http://forums.pelicanparts.com/8486458-post35.html
The fuse box for your 1974 car has 19 fuses in a row. Number 17 should have a Red/Black wire to it from the flasher relay. It is called S17 on the schematic.
You might want to read up on this as well.
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
