Spiderman
Tapping Screw or Fender Screw
Is this part available at our host or does anyone have a few spares?
4.8 x 14 with 8mm hex head. I'm missing a few for re-assy, can't seem to keep myself from dropping them. Not really identified on the PET that I can see. Please PM or e-mail. I'd buy 4 or 5 from someone if they will part with them. Thanks.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
These aren't the one's that Porsche Supply as they have a Type 'A' Point which is sharp.
The correct screw has a blunted or Type 'B' Point They should be a 6.3mm x 19 long and part number is 900.187.010.02 The early cars used a screw with a 'K' embossed on the head but they are now plain and generally in stock at Porsche. |
Spiderman
I'll use what-ever works. I just know that all my lower valance pieces use 2 or three identical to this. Tip is pretty sharp, they measure 4.8 mm dia. and length under the washer is 14mm. They go into the speed nut attached to the fender lips. I saw that 6.3 screw on pelican, maybe it would work just fine, its just not the same. The PET as near as I can see shows a 4.8mm screw (which is what I measure here) but shows a separate washer ? I really like these but I have no part number.
The screws I put the part number for are the fender mounting screws.
The screws that hold the steel valence to the aluminium bumper section on the SC are the same size and Part Number. The screws that hold the rubber mounding to the bumper are 4.2 x 13 and again should be a Type B - Blunt screw Illustration 802-00 on the PET |
Spiderman
These hold the 4 small valances at the front and rear of each wheel up to the fender on the body. At rear, that valance attached upward only to the body using 3 of these and attaches to the studs on the bellows.
At front, there is a small piece that attaches up to the fender, front to the bellows and down to the big valance that wraps around under the bumper. All valance screws are these 4.8 mm pcs with integral washer. On PET 802-01, year 89, Part 16, 900-187-018-02 is a 4.8x16 Tapping Screw, qty. 8. Also a 4.8 speed nut. This shows a washer but my screws have that integrated.
Spiderman
I don't think that 900-187-018-02 is what I want, although it may be all that's available to order.
Spiderman
Anyone have a few of these ?
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
86FlatSix
Let me check on my tool box. I recall going to Paul Miller Porsche in Parsippany and ask for these screws for ny valance and sales rep just gave me for free almost identical replacements 8 pcs of them and recall have at least 4 extra one.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Spiderman
Thanks for the reminder about Belmetric Kevin, they have a great selection ! I made a note for my file and future.
I found 3 of them
Lorne M
83 SC |
Spiderman
Seems I may have a couple coming from SWS911, Steve. Thanks. Greatly appreciate the offers of more but hope I'm good now if they arrive.
