-   -   77 Power Windows not working (http://forums.pelicanparts.com/porsche-911-technical-forum/853861-77-power-windows-not-working.html)
Gulfblue 02-28-2015 03:46 AM
After I replaced the the power mirror on my 77 with an earlier type, the windows will not operate. Can this have to to with the disconnected cables to the mirror ?
bkreigsr 02-28-2015 07:04 AM
When you did the mirror wires, you probably juggled one of the tiny little terminals on the 5-pole window switch. The switch is only about 1.25" x 1" so, good luck removing, testing, and re-installing.
If you did the passenger side mirror, there's a crossover wire that goes to the drivers side switch and will disable the whole system if not firmly seated.
Bill K
Gulfblue 02-28-2015 07:46 AM
Thanks, I have to dig in to this. Thougt maybe I broke a path when I disconnected the wiring to the mirror.
bkreigsr 02-28-2015 08:43 AM
Originally Posted by Gulfblue (Post 8508978)
...Thought maybe I broke a path...
That possibility also exists.
