LinkBack Thread Tools Rating: Thread Rating: 8 votes, 4.00 average.
ER ASP rear springs
Has anyone used the Elephant Racing ASP rear spring set-up? Would like comments on this before I pull the trigger. My car is a highly modified 930 with probably a 80/20 street/track use.
Thanks,
Mark
Old 08-23-2011, 07:20 AM
stv951's Avatar
BUMP
Any one tried these ?
Old 11-19-2011, 01:43 PM
Send a message via AIM to morrisjm1 Send a message via Yahoo to morrisjm1
Mark,
I recently finish a complete suspension rebuilt/upgrade including the ASP. I replaced all the stock bushings with ER poly bronze, 21/27 hollow TBs, Bilstein HD front and rear, new ball joints, turbo tie rod ends, put new bearings in the rack and pinion box, mono balls front and rear.
I could not be happier with the setup, but because I did this all at once on a car with 217000 + miles, I can't specifically address the ASP's contribution. Originally, I hadn't planned on the ASP, because of the cost, but when I found that one of my spring plates was bend, so I splurged. I also installed the Quick Change splined hub.
The intent is to eventually get it down to the track. It handled very well, even with the old parts. Now, it handles like it's on rails. Very responsive, turn the wheel and it immediately tracts.
Sorry I can't pin point the the exact contribution of the ASP, but I'm very happy with it.
Mike
'78 911SC Targa (SCWDP member #17)
'74 MGB (one owner)
Pickup
2013 Ford Explorer Sport
2013 VW Golf TDI
Old 11-19-2011, 05:20 PM
stv951's Avatar
Originally Posted by morrisjm1 View Post
Mark,
Mike
Good to hear that someone here has installed these without any issues.
How hard is it to adjust ? I am planning on a very similar setup as well.
Old 11-19-2011, 11:37 PM
Alright - only a 3 month span from my original question to some kind of response.
sv951 - dude, what were you doing. Had to be bored to find this old post.
Thanks morrisjm1 for your response. How was adjusting this unit. I spoke to Chuck at Rennsport about this product, and he was very technically helpful. Had to pry out a little info though - sometimes Chuck is just too serious - needs to relax some. But great products.
Keep me posted how its working
Thanks,
Mark
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 11-20-2011, 08:04 AM
I certainly would like to hear some feedback on this product.
Dean
Old 11-20-2011, 08:20 AM
Mark,
The adjustment is explained in the instructions and is pretty straight forward. I just eyeballed the adjustment for the front and rear and drove it 60 miles for new tires, an alignment, and corner balance. If you are not replacing the tires, then you need a fairly close alignment shop or a better eye than I have, because the tires were pretty scuffed up when I got to the shop and if it was raining I think the drive would have been dangerous. The shop was familiar with the ASP and had no problem setting the car up.
If you are contemplating the ER products I suggest you download the installation instructions from the web site and give them a look while you're thinking about the purchase, to get a feel for what you're up against. The instructions are very good and you shouldn’t have any problems. I made one mistake; I installed the rear poly bronze bushings, per the instructions, before I decided to go with the ASP. So the grease fittings are not where they should be. It is very difficult to get a grease gun back there, if fact, it looks like I’ll have to grind a nozzle down to get one back there. In college I worked at a concrete plant and I’m sure the grease monkey had a fitting that would do the job, but I haven’t found one yet. If you are planning to use poly bronze bushings and the ASP, I would align bushing grease fittings with the ASP’s grease fittings.
Mike
'74 MGB (one owner)
Pickup
2013 VW Golf TDI
Old 11-20-2011, 09:58 AM
Chuck Moreland's Avatar
I could use a little relaxation, that's for sure
Mark I think I remember speaking with you an Rennsport, but I must have talked to 1000+ people.
If anyone has specific questions, I'll be happy to answer.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-20-2011, 08:25 PM
RETIRED
Joe Bob's Avatar
Chuck has always seemed relaxed to me. Maybe because he never takes someone wearing bunny ears, serious.....
2012 ML350 3.0 Turbo Diesel
Old 11-21-2011, 05:52 AM
Just trolling through threads, taking some time off while my eyes heal...and wondering how the ASP system (which I have and will be going on my Carrera 6 speed project) has been working out.
I am planning on just street driving, like the idea of better adjustability and camber change and would love to hear experiences from people who have had it on their cars for a few years....
Dennis
Old 03-01-2015, 08:09 AM
