I'm about to install a Dansk single-in/single-out sport muffler on my 84. Do I need to use a sealant on the gasket? If so, any suggestions?
Thanks.
1984 Targa |
Nope on the sealer, you might want to use some anti-sieze on the bolts unless you are using stainless.
Good luck.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
"Nope" as in don't use any, or "nope" as in you don't know?
Thanks, Marc.
1984 Targa |
Senior Member
It only makes a mess and it's not necessary if the surfaces are straight and clean. When they leak, in my experience, it's because they're not straight. If they're not straight, then sometimes 'goop' will seal them. There's goop now that does a good job of expanding and sealing.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Nope as in don't use any
![]() SM is on point.
Thanks, guys!
1984 Targa |
While I agree with the above, Permatex Ultra-copper sealant works very nice on header to block gaskets, I use it on my V8 cars all the time and used it on the P-car "just in case" besides it's an ounce of prevention that is easliy removed if need be.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
What about on the gasket at the muffler flange?
1984 Targa |
NO need for it Scott.
