#147 of 2096
How to manually close a sunroof
Hi,
I need to completely close the sunroof of a 73t. Electrical motor is not working for the moment. How may I do it ? Any manual way? Thanks.
#147 of 2096 |
if its the same as my 82 open the zipper and there is a little rubber union between the motor and the mechanism just turn it with your fingers itll take a while.
82 SC , 72 914 |
Disbanded
my car does not have one....
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Keen 915 operator
When the cables broke on my '82 (with the sunroof open), I was able to pull on the sunroof part of the headliner and slide it back. On the sliders on either side, there were two steel prongs. I used those to pull the sunroof closed and lock it in place. Hope this helps, unfortunately I don't have pictures of the process.
Google 911 sunroof tool. You might have one in your toolkit.
#147 of 2096
Ok, thanks.
#147 of 2096 |
Sunroof emergency crank.......
1988 Carrera
I would advise everyone that has a sunroof to go out and try to use this tool. On my car the screw that you have to loosen was so tight. Road side fix was not going to happen. Glad I did it in the garage just for kicks.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
I didn't have the sunroof tool in my '88 kit. Can it be used on the '88 sunroof? I remember unzipping the liner, but didn't see anywhere such a tool could be used so I thought it wasn't useful for an '88. Am I wrong and in need of a crank just in case?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
1988 Carrera
jlex: You need the tool pictured above. You must remove 3 screws that hold some cardboard that covers the motor.
