ChrisP911's Avatar
Pedal cluster, WTF is this......
So I wanted to take my pedal cluster out so I can clean up all the crap built up in there and also rebuild them. So I take the two bottom bolts out then work my way to the top one and for some reason my socket wont fit on the bolt. So I go look and the damn bolts are welded to the cluster frame REALLY ......
Old 03-04-2015, 05:11 PM
ahead of the curve
Jeff Burger's Avatar
they act as studs if you go under the car and take off the protection pan you can remove the nut on the other side
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 03-04-2015, 05:17 PM
Yep, Completely stock, they are all like this.
Old 03-04-2015, 05:21 PM
ChrisP911's Avatar
OH BOY i feel like an idiot
Old 03-04-2015, 05:26 PM
The original Non-Servo Pedal boxes used these bolts to hold the Master Cylinder which was fitted outside the passenger compartment and was concealed by the Rack Protection plate.
There was a hole in the floor the same size as the hole in the cluster housing and a push rod fitted to the pedal operated the master cylinder.
Old 03-04-2015, 05:30 PM
ahead of the curve
yup we have all been there and most likely will be there again
wolds's Avatar
FYI, I just pulled my pedals over the weekend and tackled the removal of the roll pin using the drill method. It worked very well and when I stepped up to the third bit that I was going to use it went about a third of the way into the pin and hooked it at which point the pin started spinning in the hole and I was able to pull it out with the drill bit. I started with the first bit that was slightly larger in diameter than the hole and then went up one fractional size at a time. Nice and slow with a little tap magic on it.
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-04-2015, 06:44 PM
Derek911's Avatar
I am reading the entire Bentley book and just read through the pedal cluster section today. It mentions taking off the access plate under the car to get at the nuts for the pedal cluster.
Old 03-04-2015, 08:23 PM
Almost Banned Once
sc_rufctr's Avatar
Don't feel bad. A lot of what Porsche did years ago looked a bit DIY. Those bolts are a good example.
Another example... Some earlier cars had cast iron weights in the front bumper to improve handling.
- Peter
Old 03-04-2015, 08:40 PM
