3.2 carrera side script
Hi
I'm going to add the Carrera side to my 3.2 as you can see in the attached photo. Mine is white with black wheels. Can someone tell the gap between the top of the black strip and the bottom of the Carrera? It looks like the same distance as from the bottom of the black strip to the bottom of the sill. Plus I was think a satin black as that's what the wheels are painted. What have others used, Matt or gloss? Thanks for your help Alex.http://forums.pelicanparts.com/uploa...1425759397.jpg |
Carrera position
The factory specs are:
The bottom of the script is 50mm(about 2 inches) above the rocker panel molding. There is a specific location for the script on the door. Left door. Align starting the letter" C "1cm behind the forward door edge. Right door. Align point of letter "A" at the forward door edge.http://forums.pelicanparts.com/uploa...1425832215.jpg http://forums.pelicanparts.com/uploa...1425832245.jpg |
Thanks.
| All times are GMT -8. The time now is 12:58 AM. |
