LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
I'm in I have a 2000 Boxster S. Can you make a race mode (flashing) and street mode standard. Let me know when I can order
Old 03-08-2015, 02:25 PM
LED brake lights........
Spoke,
I would like to get 2 sets of these LED brake kits. Please PM how to send the payment. And hold the shipment till end of March. Thanks.
Tony
Old 03-08-2015, 04:37 PM
I would also be interested in a set for a 930, let me know when available. Thanks, Ken
Old 03-08-2015, 05:23 PM
CBRacerX's Avatar
Sign me up. And how about reverse lights?
Chris
https://dergarage.com
'80 SC Weissach, '01 986S, '99 C2 Cab, '97 TJ, '01 Disco SE7, '06 KTM SM950
Old 03-08-2015, 06:07 PM
universeman's Avatar
I'll take a pair, thanks. Agree, would be nice to replace brakes, reverse, and flashers also in one big kit.
Jason - Austin, TX
82 911 SC targa
Old 03-08-2015, 06:34 PM
Brake LEDs
Hi Jerry
So glad that you're making these for 911s too. Put me down for a set for my '87 Carrera.
Bob G
Old 03-08-2015, 07:00 PM
Thanks for the feedback.
Here's where I'm at with these lights. I did one small prototype run of 3 boards to check fitment. Got them close, but need some adjustment. I will make the adjustments and run a couple more boards. If these work, I will order a larger quantity. They have to be right and fit and work well.
I buy the boards and assemble them by hand, one at a time. It's a slow process but it's the only cost effective way to do it. I have a colleague to help with the assembly.
I need some help though; I'm not familiar with the 911 family over the years. These boards fit my 1986 930 brake lights. How many years of the 911 had the same brake light fixture size?
I am planning to do the rear turnsignals as well but these will be later.
I've thought about the backup lights as with the 914 but the whole point of these is to increase safety so people won't use our cars as battering rams as they text/email/sleep behind the wheel.
Old 03-08-2015, 07:01 PM
Originally Posted by Rleog View Post
Hi Jerry
Hi Bob,
I've been sitting on these for quite a while because I couldn't figure out a nice set of clips like I did for the 914 LED boards. Finally had eureka moment this weekend as I experimented with different plastic clips that I made with my new 3d printer.
I feel comfortable moving forward now.
Old 03-08-2015, 07:09 PM
84 911 3.2 Coupe
Arne2's Avatar
I believe the same fixture was used on all LWB cars, '69-89.
- Arne
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
Selling soon - 1984 911 Carrera coupe, arriving soon - 1972 911T coupe.
Old 03-08-2015, 07:56 PM
I see you are in Allentown, PA. Are you coming to the Hershey Swap Meet this year? If you do, can you bring a set for me to purchase?
Juergen
'86 Carrera Cabriolet Grand Prix White
'14 VW Jetta 1.8L Turbo
'10 VW Touareg
'09 VW Beetle Convertible
Old 03-09-2015, 05:22 AM
Len 911's Avatar
I would like a set also, What is the cost for a set. Nice work
Len
Old 03-09-2015, 06:31 AM
SweetWaterSurprise's Avatar
same here
Old 03-09-2015, 08:07 AM
Air Cooled
Craig_D's Avatar
Len
From post #3:
"The price will be $90 for a pair + $10 shipping (CONUS)."
'78 911 SC "Blackjack" & '76 914/4 "The Blue Brat"
2012 Ducati Multistrada S, 1994 Ducati 900SS LWCR
1990 Honda Hawk GT, 1988 Honda Hawk GT,
1977 Honda CB750K Cafe
Old 03-09-2015, 09:39 AM
Eng-o-neer
Tremelune's Avatar
Philips has a set of low-draw LED bulbs readily available for $40 a pair. They are bright in all directions, and are a drop-in replacement for 1156, 1157, and a few other standard bulbs. They're DOT-approved as well.
http://www.amazon.com/gp/product/B00HV25XUM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Old 03-09-2015, 02:31 PM
The turn signal flasher may/probably not work correctly as it depends on a certain current load to operate correctly. Might need a load device/circuit inserted in the turn signal circuit or a correct LED-compatible flasher to fit the factory 4-pin connector.
Here's nice-to-have features I would appreciate:
- Instead of a square light pattern, format the PCB with an array of LEDs in a circular pattern (e.g. 2" dia.); This creates a circular, 911R-type look to the rear.
- Angle the outer rows outward to increase the angular light cone.
BTW, nice job.
MHO,
Sherwood
Old 03-09-2015, 06:28 PM
Originally Posted by Tremelune View Post
$40/pair, from Philips...DOT approved:
Amazon.com: Philips 12899RX2 X-treme Vision LED Rouge 1157 P21/5 Brake/Stop Light (pair): Automotive
They are bright in all directions, and are a drop-in replacement for all 1157s.
They look interesting. Have you tried them out?
I just ordered a pair of these to evaluate them.
Old 03-09-2015, 07:20 PM
BTW, nice job.
MHO,
Sherwood
Do you mean like this?
Old 03-09-2015, 07:24 PM
Yes, but why not include the inner rows? Otherwise the lit taillight looks like a donut (nothing personal against donuts). IOW, make it solid red for more light volume like your solid red square, except it's round like the light pattern from these, but much more visible than what these weak bulbs produce:
photo courtesy: Widebody (but he doesn't know it)
Sherwood
Old 03-09-2015, 08:33 PM
Like this?
Old 03-09-2015, 09:11 PM
Like this?
That's what I had in mind. However, not sure about the resultant lighting effect. I noticed this LED cluster pattern isn't as tight as your previous 2-row donut layout. Perhaps provisions for resistor mount area on the back side? I'm guessing folks here might prefer less a contemporary Audi-like taillight look for a more vintage, single-source "bulb" appearance.
BTW, there's a random LED around the 11 o'clock position (inside the outer ring). An extra copy and paste element in the mockup?
Thanks for your patience.
S
Old 03-10-2015, 12:02 AM
