LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
I will take a set too. thanks.
Old 03-10-2015, 05:46 AM
Eng-o-neer
Tremelune's Avatar
Originally Posted by spoke View Post
They look interesting. Have you tried them out?
I put one on my vintage motorcycle with super weak power output. It's brighter than an 1157 from every angle.
Old 03-10-2015, 08:00 AM
Alexm930's Avatar
Subscribed!!
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 03-10-2015, 10:50 AM
Eng-o-neer
Tremelune's Avatar
Oh yeah, here's my review:
Philips X-treme Vision 1157 LED taillight bulb
Old 03-10-2015, 11:00 AM
Originally Posted by Autoban View Post
I see you are in Allentown, PA. Are you coming to the Hershey Swap Meet this year? If you do, can you bring a set for me to purchase?
Juergen
Hey Juergen,
Yes, I am planning to bring a couple of sets of 911 LED brake lights to Hershey. I'm bringing some 914 front and rear LED board sets as well.
Old 03-11-2015, 08:00 PM
Originally Posted by Tremelune View Post
Nice evaluation. Thanks. Always like to see what's available. When I get my Philips set I will evaluate them WRT to the 1157 and the LED boards I'm working on. I have a light meter which is perfect for this analysis.
Old 03-11-2015, 08:09 PM
84 911 3.2 Coupe
Arne2's Avatar
One of the things that concerns me about some of the LEDs I've seen is that the difference between tail and brake is not as great as an incandescent bulb. Both are typically brighter, and the response time is much better, but I'd like to see better difference between the two functions, especially in our Porsches where the tail and brake lights share a section of the light. I actually much prefer separate single circuit lamps - tends to make it more obvious when the brakes are applied.
- Arne
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
Selling soon - 1984 911 Carrera coupe, arriving soon - 1972 911T coupe.
Old 03-11-2015, 08:38 PM
Banned for Life
RSBob's Avatar
Spoke has a quality product and has great sales and a following on 914 World.
I opted for a less expensive alternative which I am more than happy with but it isn't as nice a product as Spoke's. https://www.superbrightleds.com/moreinfo/s-series-bulbs/1157-led-bulb-dual-intensity-45-smd-led-tower-/814/ In red.
Update, I may add to add resisters since my brake warning light is on and cruise is not working.
Now back to your regularly scheduled thread already in progress
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 03-11-2015, 08:47 PM
Understood. It is sometimes difficult to see the difference between the brake intensity and running light intensity. The 3rd brake light is sometimes the only way to tell the difference.
I've tried to make the difference between brake and running light quite obvious. I run the brake LEDs at about 20ma and the running lights at about 4ma. The difference in intensity is about 5:1 as observed in the graphs in the first post.
There is one aspect of LED brake/tail lights that should be of great concern: heat. I don't know how the LED towers and other products handle the heat. I've tested my 914 and 911 brake boards for long periods (hours) with brake lights on at 14V to determine the temperature rise. I burn about 4W on a 3.5 x 2.5inch 914 board with a 25C temperature rise. I don't know how Philips burns 2W on such a small fixture.
The 914 LED boards at brake intensity operated at 14V runs about 20-25C above ambient. The 911 LED boards run about 30C above ambient.
A critical temperature for LEDs is about 100C. At this temp wire bonds and P-N junctions fail. It is important to stay below this temperature. I estimate my boards will stay well below 100C. Even at 110F (43C) (Arizona guys?), these boards will only run at 43+30 = 73C. Well below the critical 100C.
Many trucks and trailers run LED tail and brake lights now. I've seen some starting to fail where a couple of the LEDs are out. Maybe this is due to heat or vibration.
Of course LED failures are not only the domain of aftermarket truck lights. Check out this Nissan I was following. Just one of the LEDs is out on this vehicle. How do you replace this LED? How many of these LEDs have to fail before this vehicle will not pass state inspection? How much would it cost to replace this LED display?
Old 03-11-2015, 10:01 PM
Hey Juergen,
Great, I meet with a bunch of Pelicans at the Crab Cake Shack at noon every year. We can meet there if that is OK.
Juergen
'86 Carrera Cabriolet Grand Prix White
'14 VW Jetta 1.8L Turbo
'10 VW Touareg
'09 VW Beetle Convertible
Old 03-12-2015, 04:45 AM
joe payne's Avatar
I have a set of the Phillips Extreme Vision LED's. I'll try to put them in this weekend and see what's up. Designed in Germany/Made in China..
jtp911
Old 03-12-2015, 09:02 AM
redturbo911's Avatar
Interested keep us posted.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 03-20-2015, 11:16 PM
Uncertifiable!!!
Uwon's Avatar
Subscribed. Spoke, your boards Look really good. I'm planning LEDs for my RST build but am concerned, as expressed by Arne, about the apparent lack in differentiation between tail and brake mode with some 1157s. Joe, do post your finding, please, hopefully with some picks.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 03-21-2015, 04:04 AM
Got a couple more boards in with some adjustments made from the first set. I still forgot to put some holes to attach the wire "handle" on the board. The handle is necessary to position the board and to remove the board if needed.
I will build up these boards and offer them to a few folks.
Some have asked if these are plug-n-play so I made a video of the installation of the board. In the video you'll see a plastic frame that I made with my 3d printer. These will be provided with the board as well as a 7/64 inch allen wrench to secure the board.
It took less than 3 minutes to install one side.
Old 03-22-2015, 04:51 PM
SWEET, but with 3 911s & 3 914s, that could get a bit pricy..
http://www.bvdmotorsports.com
Active Rennlist Member.
http://members.rennlist.com/racerbvd/
See blog for my For Sale & Wanted List.
http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337&
Old 03-22-2015, 05:41 PM
911SC Tinkerer
I'd be interested in a set.
-'83 911SC Coupe
SSIs, Dansk 2in - 2center-out, Street Fire Ignition, Copper plugs, Instagram: @ Zinnmetallic_sc
Old 03-22-2015, 06:26 PM
At 6 min per install, buy one set and switch it around.
Bob G
Old 03-22-2015, 06:59 PM
Uncertifiable!!!
Uwon's Avatar
Spoke,
I'd be interested in a set too.
Johan
Old 03-22-2015, 07:05 PM
DocHop's Avatar
Spoke,
I would like to order a set as well.
Peter
Old 03-23-2015, 06:11 PM
Anyone going to Hershey this weekend? I have 3 sets of 2nd generation prototypes to sell. Would really like to see these installed in 911/930 to make sure they fit well.
Thanks for all the feedback. Once I have the feedback that these fit on other's cars, I will do a larger run.
Also working on a rear turnsignal LED board. I should have the first prototypes this week. This one is really wild. It has LEDs pointing in all directions. For US spec turnsignals (red), it will replace the side lights and will light gently with the running lights to give the 911 a larger visual footprint at night.
Old 04-15-2015, 07:38 PM
