-   -   Tunnel throttle linkage bushing replace (http://forums.pelicanparts.com/porsche-911-technical-forum/855063-tunnel-throttle-linkage-bushing-replace.html)
Charles Freeborn 03-08-2015 12:18 PM
Time to do them. Any suggestions on sequence?
Will pull pedal cluster at the same time and re-bush.
Thanks,
-C
JJ 911SC 03-08-2015 12:37 PM
If these are not the ones you are talking about and can stomach $27 for 3 pieces of plastic... replace them.
Actually you might not even find them, I only find a piece of one.
901-423-227-00-M253
http://forums.pelicanparts.com/uploa...1425843435.jpg
JJ 911SC 03-08-2015 12:49 PM
I also replace the Throttle Rod Coupling
901-423-227-00-M253; 1970 Porsche 911 T Coupe/Targa - Fuel System - Page 4
Charles Freeborn 03-08-2015 02:05 PM
Those are them. All three new ones in hand. Throttle coupler done already.
Thx.
JJ 911SC 03-08-2015 02:34 PM
Good.
Well to put the bushing in, you'll need to removed the shifter.
Since you are removing the shifter... How about a "shifter" up-grade (love to spend someone else money :D:):D).
Charles Freeborn 03-08-2015 04:16 PM
Shifter is done too - stock at least. New cup and bushing made it work like new. Maybe a WEVO one day...
tshebib 03-08-2015 05:00 PM
Be sure to check the weld on the throttle lever.
http://forums.pelicanparts.com/uploa...1425859142.jpg
http://forums.pelicanparts.com/uploa...1425859196.jpg
JJ 911SC 03-08-2015 05:13 PM
Originally Posted by tshebib (Post 8521286)
+1, Had the same problem. Just could not bring myself to pay $65 for a new one...
Originally Posted by JJ 911SC (Post 8062031)
My friend straighten the bracket, turned a new pin (from a 12.9 bolt), press it in and miged the bolt end to the bracket.
Crocked and wobbly:
http://forums.pelicanparts.com/uploa...1399992735.jpg
Came apart:
http://forums.pelicanparts.com/uploa...1399992709.jpg
The pin was too short to work with:
http://forums.pelicanparts.com/uploa...1399992785.jpg
New pin pressed and welded
http://forums.pelicanparts.com/uploa...1399992804.jpg
Charles Freeborn 03-09-2015 08:26 AM
Nice job on the linkage. I think mine's okay, but we'll see when I dig in there.
-C
