Worn out transmission
I own a 1982 911 SC. My transmission is in pieces at the mechanic shop and my mechanic is telling me it would be more cost effective to buy a complete rebuild from Vertex Auto. I live in Portland Oregon and Vertex is in Florida.
I had a complete engine rebuild 2 years ago and now the transmission is toast. I bought the car with my heart and not my brain. I still like the car and want to get the transmission rebuilt. Does anybody have any suggestions? I love the car and plan on keeping it.
Old 03-06-2015, 07:37 AM
gearhead
Rennsport Systems in Portland. Don't buy a vertex gearbox. Search and you will see why.
Old 03-07-2015, 08:43 AM
TheSt|G's Avatar
Vertex is pure garbage. Close to Motor Meister 2.0
Old 03-07-2015, 09:01 AM
evan9eleven's Avatar
What Matt said. Steve at Rennsport is the man!
Old 03-07-2015, 09:29 AM
915 build
Another excellent 915 specialist is John Walker in Seattle...
Old 03-07-2015, 11:14 AM
Under the radar
Trackrash's Avatar
As long as your gears are good, I would rebuild what you have.
If you buy a "rebuilt" trans, you have no idea of it's history, abuse, or parts quality.
What was wrong with your trans that caused you to remove it?
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-07-2015, 01:40 PM
HarryD's Avatar
Steve (Rennsport) or Kurt (Marque motors) are straight shooters. They will do you right. If cost was not a primary consideration, I would add Rothsport.
Old 03-07-2015, 01:49 PM
kodioneill's Avatar
Plus the car is worth more if you have a matching numbers transmission. Do not buy the Vertex, bad idea.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-08-2015, 08:09 AM
What is unrebuildable to one guy, is a normal repair to others.
206 637 4071
Old 03-08-2015, 09:58 AM
gearhead
Signature worthy quote.
Old 03-08-2015, 10:18 AM
kevingross's Avatar
Amen to that.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 03-08-2015, 10:21 AM
Rescuer of old cars
Arne2's Avatar
Rothsport in Sherwood does transmissions, too. A friend had his done there, said it has never been better.
Lots of choices in the Pacific NW.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-08-2015, 10:44 AM
Anyone know of a good guy in the Upstate NY area??
Old 03-08-2015, 11:15 AM
gearhead
I'd be interested to hear exactly what is wrong with the gearbox. To remanufacture one can run several thousand dollars. But you could buy a "good used" 915 for $1500 that still needs another $1500 in work to make it right. Better the devil you know...
Old 03-08-2015, 07:40 PM
Cooper911SC's Avatar
Get a second opinion for sure.
I am an owner/keeper type.
My '81 SC is at 312k miles now.
Second gear box rebuild.
This time around I sunk some real $$$ but very worth it to me.
Had the WEVO machine work done for steel insert for Main/Pinion bearing support and axle bearing. ~$1,400.00 for that.
Plus the "big" MS/PS bearings $
CMS 1 piece retainer.
Then the normal wear items, synchro's/dogs etc.
Not a cheap ordeal but quality work and I own the car...
(Engine is still original! Waiting to see what breaks)
Cooper
Old 03-08-2015, 07:54 PM
kodioneill's Avatar
One mans ceiling is another mans floor!
1982 chiffon 911sc
Old 03-09-2015, 03:13 AM
