North Coast Cab's Avatar
Valve Cover Clipped Corner?
So I've got the car on stands to prepare the winter project list. As I'm reviewing the numerous oil leaks and their sources I check the valve covers. The drivers side lower cover has the corner cut or ground off. Is this intentional? There are no valve cover oil leaks and lower gaskets look clean and green. What do you think?
JG
1985.5 944 GTS
Old 10-26-2002, 01:21 PM
Do a search and read some old posts.
I seem to remeber something about a certain model having to do that, maybe the sportmatic, I think it had a pump that was sort of close.
Jeff
911T
Old 10-26-2002, 02:49 PM
Author of "101 Projects"
Wayne 962's Avatar
If your oil lines are not installed properly, the corner of the valve cover gets in the way. The solution is to move the oil line slightly - not machine the valve cover. I'm not sure about the Sporto problem though...
-Wayne
Old 10-26-2002, 02:54 PM
There's plenty of clearance from the oil line. It's an '84 Cabriolet. The wierd thing is the cover and gasket edge are as clean as can be. I can't get a good picture to see it but it looks like it was ground down about 1/2". Should I worry about replacing the cover?
JG
1985.5 944 GTS
Old 10-26-2002, 06:06 PM
Senior Member
Hello
Turbo valvecovers have 50% dished fins at the driverside.
Grüsse
Old 10-27-2002, 05:19 PM
