Banned
redducati750's Avatar
Send a message via AIM to redducati750
70E to 75S suspension swap?
ok, i bought the front suspension out of a 75 S for 200 to replace my self leveling suspension in my 70E, which struts does the 75 S suspension accept?
Old 12-28-2002, 12:53 PM
PRO Motorsports
Tyson Schmidt's Avatar
Any struts you like. I'd suggest the Boge from an SC or Carrera. The Boge will accept inserts from Koni, Bilstein, or Boge. The SC and Carrera have the wider caliper bolt spacing so you can fit bigger brakes.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 12-29-2002, 11:05 AM
Chuck Moreland's Avatar
He's already got the struts. I think he is asking what type of inserts he can put in.
Duc, you need to determine what kind of struts you have. Boge, Bilstein (I don't think konis where available on the 75?). Boge was the most common. You can get bilstein or konis inserts to go in boge struts.
If you've got bilstein struts, you can get bilstein or koni inserts.
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-29-2002, 11:59 AM
Banned
if i go with the struts from an sc or carrera will they accept the alloy S calipers?
Old 12-29-2002, 03:33 PM
PRO Motorsports
Yes, the wide spacing of the SC and Carrera are correct for the aluminum S calipers.
So which is it? Are you asking about just inserts? Or the whole strut assemblies?
2004 GT3
Old 12-29-2002, 06:51 PM
Navin Johnson
TimT's Avatar
Im just gonna throw this tid bit in
Truechoice will modify your bilstein struts, when they are done you will have 6 way adjustable koni inserts in your stock or RSR struts
Its way cool
'69 911 GT-5
'75 914 GT-3
and others
Old 12-29-2002, 07:00 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Koni was available and was on the 75S...that's what is on mine and they are adjustable.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 12-29-2002, 07:48 PM
Banned
i need to get the strut assemblies. Damm self levaling suspension..
Old 12-30-2002, 11:36 AM
Send a message via AIM to Oldporsche
Cool
Some 911E cross members will accept the torsion bar socket/adjusting pieces. If your's won't it will need to be replaced.
The "S" brake package included a larger sized front caliper. The mounting bolt holes on the ears of the uprights were 3.5" apart center to center.
Good luck,
David Duffield
Old 12-30-2002, 12:24 PM
Senior Member
I am not sure, but I think my struts are converted Hydrypneumatic's, to accept shock inserts. I have seen this referenced in Pano many moons ago, but don't have the specifics. I haven't dug around too much, but how exactly can I tell? If I still have the hydro's, will I also have the height adjust bolts etc at the end of the a-arm? Anyways, if I need to replace my struts, I have S brakes so will have to get S struts or later struts for a-calipers, correct? Last, if I go to a later set up (SC/Carrera) can I still mount through the bady sway bars?
thanks
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 12-30-2002, 04:08 PM
Banned
i already have the actual suspension cross member sway bar ect. off a 75 911, i need struts for this suspension, the owner said they were boge with the m caliper so i think the struts from the late sc/carrera will work and provide the proper bolt spacing for the S calipers
Old 12-30-2002, 04:57 PM
Banned
does anybody know if that is going to work?
Old 01-01-2003, 03:12 PM
PRO Motorsports
Yes, it will work. SC and Carrera all had the wide bolt spacing for the caliper. This is the same as the early S aluminum calipers.
2004 GT3
Old 01-01-2003, 03:57 PM
Early_S_Man's Avatar
Porsche Crest
Chris,
If there is a rubber bellows at the top as is in the pic below, then you still have the Vukolian hydropneumatic struts in place!
The second shot below shows the factory conversion kit.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-01-2003, 04:10 PM
Gasoline User
1974carrera's Avatar
Chuck, where/who is the source of Koni inserts for Bilstein struts? I know Koni used to make inserts for Bilstein struts (even have their part numbers), but Koni tells me they are no longer available. Thanks.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 01-01-2003, 05:00 PM
Bob, my information may be out of date. If koni says NLA then I'm sure that is correct.
Old 01-01-2003, 08:10 PM
Banned
willl S struts from a 73S work on the 75 suspension
Old 01-02-2003, 11:16 AM
dtw dtw is offline
GAFB
Yes. We're talking about actual struts, right? Not shock absorber inserts?
BTW, I posted to your suspension pan thread but it fell off the front page. We're probably putting in a suspension pan in my new car next weekend. I got another '72T. I'm prepping the tub now. It's RUSTY!!!
Several BMWs
Old 01-02-2003, 11:20 AM
All of the 69-89 struts will work with your suspension. You may need different ball joints if you use early struts. S, SC & Carrera struts will work with any of the calipers in that group, but not with T struts or some 2.7 car struts. We usually get $500 for a set of SC or Carrera struts. I think I have one set of Boge left. I have seen some cars come in w torsion bars and rubber bellows. Not sure where the owner got them.
Dave
DART Auto
www.dartauto.com
dart@dartauto.com
303 296 1188
Old 01-02-2003, 08:33 PM
