lespaul's Avatar
LED License Plate Bolt Light Wiring Question
78 SC. I am feeling stupid but cannot figure out how to wire up the LED license plate bolt lights I bought. I have two sets of two wires coming from each side that used to attach to the OEM license plate lights. The LED kit has a black and a red wire. I thought I would just attach the black and the red to the two wires that used to go to the old light and that would be it -- but no.
Can anyone help me on this one?
Here is a pic.
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 03-09-2015, 07:00 AM
French Import
zippy_gg's Avatar
LEDs are polarized so they only work if you connect the positive to the positive and negative to negative. Use a voltmeter to find which is which, or just try to reverse your connections and see if the light comes on. Most likely the red lead is the positive and the black one is the negative in your setup.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-09-2015, 07:32 AM
lespaul's Avatar
Thanks Gillis. I will try that tonight.
Brad
Brad
Old 03-09-2015, 08:09 AM
Air Cooled
Craig_D's Avatar
I have the same lights, and when I was test installing them, I just reversed the connection until they lit. You could obviously use a volt meter, but that meant crawling out from under the car.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-09-2015, 09:37 AM
