I am installing a 1986 915 gear box with an 84 3.2 motor in my 914
I have a 915.116.713.5R clutch lever. I am guessing its a 915.116.713.05 clutch lever. The manual says I should use a 915.116.713.06 superseded to .08 Will the .5R/05 work or should I find an 06/08? Thanks in advance for the help!!!
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. Last edited by fetus; 03-10-2015 at 10:10 AM.. Reason: Clarification |
#147 of 2096
Hi!
Your are installing a 86' 915 on which year 911? post more pictures of what you have. Thanks.
#147 of 2096 |
The car is a 1975 914 with a 1984 3.2 motor with a 1986 915 trans. All the other clutch parts match the parts list for an 86 trans but the clutch arm.
Here is another picture.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
Bump!!
Helper spring clutch arms are basically all the same. Retainer on large spring or a pin hole high up toward the trans
They all do the same thing with the same adjustments. Bruce |
