911 SC LED Turn Signal Conversion
Good morning Pelicanites,
I was tinkering with the idea of converting my stock turn signal/ brake / reverse incandescent bulbs to LED. I see there are what appears to be plug and play replacements via a few websites, including, superbrightleds dot com. Have any of you had experience with these? will the light loads from the LEDs affect function? any comments or suggestions are welcome. 79 SC |
You should reach out to Etarga and get the bulbs from him. There may be cheaper options, but you get what you pay for and his are top notch and warrantied. I have them in my SC and love them.
The only issue you will run into is with the turn signals. With the lower current draw, the flasher will flash fast as it does when a bulb is blown. There is a tread on this forum with a solution using a BMW flasher, but I haven't tried it yet. |
Excellent - just sent him a PM thanks for the quick response
| All times are GMT -8. The time now is 12:00 AM. |
