What kind of 911 do i have?
Hello
New user here from Norway, making first post :) I recently bought a 1977 Porsche 911 2.7 CIS, Chassisno: 9117302401. The car has been sitting in storage for 17 years, and is in decent condition. Originally imported from Germany. The car has Turbo-look on it. Ive tried to figure out if this is original mounted on the factory or if it was rebuilt later, but havent been able to come to a conclusion. Did the cars with factory turbo-look come with different brakes? The car has 8x15 and 10x15 Fuchs wheels on it. What are these called? I Understand the 78 onwards with 3.0 are called SC. Is mine a 911S? What are the main chassis differences between mine and the SC? As im thinking of converting to 3.2 and G50. Thanks for replies :) Tommy http://forums.pelicanparts.com/uploa...1426020119.jpg http://forums.pelicanparts.com/uploa...1426020172.jpg |
You have one of the last 50 1977 911 normal ROW chassis made.
Look around at that tail closely. It might be factory. If so, it is worth some money. Also look at the part numbers and date on your wheels. Also worth some money. The flares are NOT original to the car, but could be factory steel.
Looks like it's a 911S to me.
The 3.2 will be an easy swap but the G50 swap is a MAJOR bit of work to change out the torque tube and the back seat area sheet metal. It can and has been done and I'm sure if you search you can find info. The 915 trans in there now can handle the 3.2 just fine. |
Thanks alot for your help guys :)
So i have to change some of the rear Seat sheet metal as well? Going 3.2 turbo, and dont like mating that up to a 915 :) |
Nice project enjoy! |
Thanks for yours replies guys.
The wheels have porsche part numbers and are genuine fuchs 8x15 and 10x15. I fully intend on keeping the turbo look :) http://forums.pelicanparts.com/uploa...1426076775.jpg http://forums.pelicanparts.com/uploa...1426076808.jpg |
If they are 11x15, they are worth some serious money. They look more like 9x15 wheels to me, than 11x15. JR |
Sry.
By measuring the rear wheels i found out that these are in fact 11" wide. The part no on them are 911.361.020.11 as seen on the pic. http://tapatalk.imageshack.com/v2/15...75d16b8943.jpg http://tapatalk.imageshack.com/v2/15...9223ea05e2.jpg |
911.361.020.11 is the part number for an early 7x15 wheel. That's an indication that yours have been made from part of an original Fuchs wheel and another rim that has been welded on. Look for a 7x15 stamping near the Porsche logo on the back side.
A 9x15 is 911.361.020.03. An 11x15 is 911.361.020.05 JR |
Ok
Thanks alot for the information :) |
The torsion tubes need to be modified to install a G50.
Send pictures of the rear brake disks and calipers so we can see the trailing arms as well.
Then also send pics of the front ones and the front struts. |
Rear:
http://tapatalk.imageshack.com/v2/15...398aa16660.jpg http://tapatalk.imageshack.com/v2/15...15ac2d2cf6.jpg http://tapatalk.imageshack.com/v2/15...99b754674f.jpg http://tapatalk.imageshack.com/v2/15...f0396f9bf4.jpg http://tapatalk.imageshack.com/v2/15...dfbdc61937.jpg http://tapatalk.imageshack.com/v2/15...042be6de00.jpg Front: http://tapatalk.imageshack.com/v2/15...e53e317aac.jpg http://tapatalk.imageshack.com/v2/15...d508cfa1e1.jpg http://tapatalk.imageshack.com/v2/15...8feec9f23d.jpg http://tapatalk.imageshack.com/v2/15...29f286b120.jpg Any info greatly appreciated as im completely new to Porsche. Will 3.3 turbo brakes bolt straight on here? |
Does not appear to have turbo rear trailing arms. So my guess is the wide body work was added at some point and not factory.
But it does have bilstien struts (green ones) at the front and that's nice. |
Will defer to those more knowledgeable, but real turbo brakes are mounted on the back side of the rear rotors. Those look like they are on the front side. Not sure if it matters or not when doing a swap.
a G50 can be shortened to fit in a non-G50 body, hence no welding/cutting on torsion tubes. Not cheap however. There is somebody relatively close to where I live (Munich) doing that tranny work
| All times are GMT -8. The time now is 03:58 AM. |
