-   -   While i'm there - cis removal (http://forums.pelicanparts.com/porsche-911-technical-forum/855615-while-im-there-cis-removal.html)
prebordao 03-11-2015 02:32 PM
I will remove the whole CIS setup in the next weeks.
While having complete access to the top of the engine, what gaskets should i replace to minimize / stop the typical oil leaks ?
Tks
tirwin 03-11-2015 02:54 PM
The main thing on top of the engine is the typical "triangle of death".
You should check the boots on the intake runners and the o-rings and sleeves on the fuel injectors at a minimum. It is a slippery slope though. One minute you're replacing a simple gasket and the next minute you're disassembling the engine. :)
prebordao 03-12-2015 02:08 AM
I've heard about the triangle of death... but what gaskets should I have ready, just those oil-related...
wachuko 03-12-2015 05:41 AM
Remove bottom oil drain cover, clean all of it and use two new gasket.
http://i151.photobucket.com/albums/s...psc68c34fa.jpg
http://i151.photobucket.com/albums/s...pse454b0c8.jpg
http://i151.photobucket.com/albums/s...ps8b358ba4.jpg
http://i151.photobucket.com/albums/s...ps0265fb97.jpg
http://i151.photobucket.com/albums/s...psca53a209.jpg
If you tackle the oil cooler... there is a bulletin on some fixes there as well to avoid leaks. Preventive fill of the area behind the engine oil cooler as per the bulletin...
http://i151.photobucket.com/albums/s...ps9abc8883.jpg
Oil seals. It was suggested to put some Loctite 574 on them to make sure there were no leaks... a little is enough...do not over do it...
http://i151.photobucket.com/albums/s...ps77330035.jpg
Attacking the triangle of oil leaks... again... some little bit of Loctite 574 on the gaskets as well... DO NOT PUT Loctite 574 on the o-rings... only on both sides of the gaskets... just making sure that was clear
It is this O-ring, the oil breather cover gasket, and the sensor (seal and actual sensor...the sensor itself is a source for leaks)...
http://i151.photobucket.com/albums/s...psefb41a61.jpg
http://i151.photobucket.com/albums/s...pse85aff64.jpg
Triangle of leaks done!
http://i151.photobucket.com/albums/s...ps37510899.jpg
prebordao 03-12-2015 05:43 AM
Thanks !
wachuko 03-12-2015 05:56 AM
Originally Posted by prebordao (Post 8526902)
Thanks !
Also, if you do not have it... download the parts catalog for your car... here is the link for the USA cars... but this is free and available from the Porsche website...
http://www.porsche.com/all/media/pdf/originalparts/en/E_911_77_KATALOG.pdf
Part numbers are:
Crankcase top breather gasket (930-107-791-02)
Temp Switch Seal (located on the crankcase breather cover) (900.123.007.70)
Oil Thermostat O-ring (999-707-314-40)
Oil Pressure Switch (911.606.230.00)
Oil Pressure Switch seal ring (900.123.009.20)
prebordao 03-12-2015 07:37 AM
Thanks, I have the PET, but you saved me some work.
tirwin 03-12-2015 07:56 AM
Originally Posted by wachuko (Post 8526899)
Some tips:
- You see the red sensor in the bottom right? Oil can seep past the pressed metal edge (just above the hex) that overlaps the base of the red plastic. Put some epoxy like JB Weld around that to seal it permanently.
- There was a great debate about the oil cooler seals. The top two are the really critical ones. The current thinking seems to be that the green seals are prone to leaking. I can't remember which brand name matches the colors but the ones you want are the reddish-brown ones (you DO NOT want the green ones). The bottom seal is ok to use the green seals on however because it is not under pressure. I couldn't find the bottom seal in anything but green.
prebordao 03-12-2015 08:01 AM
Get it, Up-Brown, Down-Green !
wachuko 03-12-2015 08:05 AM
Originally Posted by tirwin (Post 8527060)
Some tips:
I did not think about epoxy on the sensor...ha! Excellent recommendation... and on my way to doing so as the engine is still on the stand waiting for the body/paint work to be done... http://i151.photobucket.com/albums/s...ps842096f2.gif
On the oil cooler seals...red ones... was not aware of that.
tirwin 03-12-2015 02:09 PM
Something else to check is the transmission shift linkage nose seal. Mine was leaking like a sieve.
If you have the later model Carrera chain tensioner update, check for leaks at the banjo fittings on the oil lines that attach to the cam housing covers and the upper valve covers. There is a washer on the top and bottom of the banjo. I think the originals were aluminum and the replacements are copper.
