paint drip removal
Hey folks:
'87 3.2 Guards Red.
Paint is lovely, but there is a drip on the front bumper where apparently a P.O. was walking past with some Guards Red touch up for elsewhere and dripped on the bumper. It's quite proud of the surface and ran down the front of the bumper.
How would I get it off?
I'll try to post a pic.
Sheldon
Old 03-11-2015, 06:44 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Advise as to depth of experience with power buffers and the like. Micro wet sanding and polishing will always work but a little bit of time under your belt will save you grief.
Original paint? Options increase as you can moderately use solvents to cut the miscreant's slop without jacking with the base paint. 21 Line is very tough but you have to be scared.
1981 911SC Targa
Old 03-11-2015, 08:01 PM
scared
Yeah, no significant experience with power buffing. Do that stuff by hand.
As for original paint, yes, but. Does one ever really know that no area has been tampered with? Its a bumper after all. If it's not original, it's a damn good and thorough replication of the original.
Mask, sand?
Old 03-11-2015, 09:00 PM
Project Addicted
Most touch up is lacquer based and can be removed with lacquer thinner. Test on a door jamb or under hood area to see if the original reacts with thinners.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 03-12-2015, 04:22 AM
This just happened to me, single drop of touch up paint on newly painted fender. Local shop gave me a small bottle of Glasurit Reducer and it worked like a charm! Touch up paint doesn't have hardener, so it came right off. Better to remove the drip ASAP though...
Old 03-12-2015, 05:40 AM
non-whiner
mreid's Avatar
Lacquer thinner will remove non-catalyzed paint, but it can dull the surrounding paint. Reducer works really well with no side effects.
"Too much is just enough."
Old 03-12-2015, 05:51 AM
T77911S's Avatar
you may be able to wet sand it with 600 and a small block, then buff it back to a shine.
problem is how much old paint is still on there and how far down will you have to sand to get all the color off.
if it really bothers you i would try something like a popsickle stick with 600 and start by sanding just the drip. sand lightly. make sur the stick id flat.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-12-2015, 05:57 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
lets approach this with a solvent before sanding. There is a good chance it will come right off without removing any of the original paint. A small can of reducer will run you $15 at the auto parts store
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 03-12-2015, 06:29 AM
One of our paintless dent guys, who also does paintwork, would probably slice it even with a razor blade. But I know my hands are not steady enough to do that.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-12-2015, 06:55 AM
Straight shooter
Lapkritis's Avatar
I'd recommend isolating the drip with tape to protect the surrounding paint. Use more layers of tape to keep the adhesive from reacting with the reducer. Work slowly to limit work against the good paint under and around.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-12-2015, 06:49 PM
