TheSt|G's Avatar
Battery area storage
Anyone aware of any sort of storage system available for the stock battery location? I recently relocated mine to the smugglers box and would love some sort of nice storage unit for oil and such.
Old 03-15-2015, 11:40 AM
What year? Do you have dual batteries?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-15-2015, 12:20 PM
TheSt|G's Avatar
1985 Coupe, so a single battery, which is now in the smugglers box. I would like something in the stock location that looks good and secures a bottle or two of oil, some gloves, and perhaps some rags.
Old 03-15-2015, 12:45 PM
google "marine battery box" Quite a few options that might work for you
Old 03-15-2015, 02:00 PM
TheSt|G's Avatar
Perfect idea, thank you!
Old 03-15-2015, 04:00 PM
how about this?
http://www.summitracing.com/parts/sum-890103/overview/
or this:
http://www.summitracing.com/parts/sum-g1199-1/overview/
03 Boxster
Old 03-15-2015, 07:43 PM
03 Boxster
Old 03-15-2015, 07:45 PM
TheSt|G's Avatar
Looks like I need to go do some measuring. These are excellent.
Old 03-15-2015, 08:08 PM
Curious to understand why you relocated the battery. Just for looks (which I would agree cleans up the trunk)? Weight distribution wise I would think moving the battery makes things worse, not better, correct?
Old 03-15-2015, 11:11 PM
TheSt|G's Avatar
Weight savings and cleaning up the trunk.
Old 03-16-2015, 04:50 AM
I thought that moving weight towards the center did help handling.
Old 03-16-2015, 10:35 AM
TheSt|G's Avatar
It does. See Audi for an example of why hanging half the car over the front axle is a terrible idea.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 03-16-2015, 10:40 AM
except we don't drive Audis. With all the weight in the back I still believe moving the battery does no support better handling. But the difference is probably small.
Old 03-16-2015, 11:05 PM
You are probably right, remember the factory fix to the handling of early 911s was to put two weights in the front bumper to off set the rear bias.
Old 03-17-2015, 06:10 AM
TheSt|G's Avatar
Shrug, it's part of my comprehensive approach to remove and center the weight of the car.
Old 03-17-2015, 06:18 AM
Please don't take offense. I'm struggling with the same dilemma on my 1979 SC. I changed to manual window cranks, all A/C components are gone (so I have an empty Smugglers box), rear seat delete (but put a 964 DAS bar in its place) lightweight carpet and am now working on a long hood fiberglass rear bumper.
Old 03-17-2015, 06:33 AM
TheSt|G's Avatar
Manual window cranks certainly are tempting. Given how small the car is, that wouldn't be that hard to use...
All of my AC stuff is gone except the front condenser, fender mount dohicky, and some lines.
Old 03-17-2015, 09:48 AM
Then they took out the weights and put 2 12v batteries wired in parallel in the far corners of the front trunk to get that weight up front as far as possible.
Moving battery weight forward is a good thing in an early 911.
03 Boxster
Old 03-17-2015, 10:29 AM
This is another cool box from Summit and is is all aluminum for $99.00 ....pretty good deal.
03 Boxster
Old 03-17-2015, 10:32 AM
