Nevadasmith (guest)
Guest
Posts: n/a
I have a 1973 911 Porsche Targa. I need to replace the front seat belts. They both come up from the rear and thru a slot in the rear panels. How do I remove the panels and get the seat belts thru the slots? Thanks. Also what is the best book that I can get to work on my Porsche.
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-20-2015, 08:32 AM
Remove the screws from the upper portion of the interior panel, disconnect the speaker if equipped. Be careful not to mix up screws as they are usually a different length. Disconnect the seat belt and slide the pieces of belt through the trim panel. As for repair manuals for that car the factory really did a great job back then. If you're serious about keeping your car on the road look for a second hand or reproduced set of Original Factory Repair Manuals aka Shop Manual.
- Casey
