Let's try this again. Looking to add three point belts to the rear of my '85 3.2
I have the belts themselves. The rear deck cover with the proper fittings has been harder to source.
Can anyone point me in the right direction? |
no but subscribed.
Is this the one you are looking for?
I just ordered some plastic covers for the rear seat belt outlet from a Volvo on Ebay for $14 and plan on just cutting the hole in my existing rear deck to fit it.
I couldn't find an outlet cover I liked by searching for Porsche, but there's tons of stuff under every other car manufacturer. |
The first link does not look like a 964 deck. 964 should look like the one in the link below. FWIW I added belts to my 86. The anchors were already installed so the belts bolted right in. I bought a set of 964 rosettes and cut my existing deck. J
I'm sorry, it was from a 924, not a Volvo. I looked at the Volvo first and then found the ones for a 924 for $6 on Ebay.
I am not installing a retractor, however, so all I have to do is bolt the three points which makes it a lot easier to fool with. I'll post a thread on it when I get it done (if it works) |
This is the one that I ordered.
Used a 964 shelf as template and used the plastic pieces from the 964 shelf. The belts are from a 964 as well.
The 924 plastic parts would probably work, but I think the 964 parts are probably the better choice. I think I have 964 belts and retractors. |
| All times are GMT -8. The time now is 02:16 PM. |
