-   -   1989 3.2 Carrera-disabling brake pad sensor with race pads (http://forums.pelicanparts.com/porsche-911-technical-forum/856197-1989-3-2-carrera-disabling-brake-pad-sensor-race-pads.html)
89PS911 03-15-2015 04:14 PM
Hi All,
I plan to install new performance brake pads on my 1989 3.2 Carrera. Since it seems some brands do not have slots for the pad wear sensors, do I need to disable my pad wear sensor system and, if so, how do I do that?
Thanks,
Jonathan
VW_NUTT 03-15-2015 04:23 PM
You could do as others on here have done. And that is leaving it connected and use a cable tie to secure it
Hendog 03-15-2015 04:31 PM
Yep, just tie them out of the way.
cashman 03-15-2015 04:39 PM
Mine are zip tied. I believe the brake warning light will come on if you disconnect the sensor. Not positive about that though.
DRACO A5OG 03-15-2015 05:16 PM
+4, yes disconnecting the sensors will open the circuit and cause the light to come on.
89PS911 03-15-2015 06:02 PM
Thank you. I will tie them off with zip ties. After this NE winter, I cannot wait to get back on the road.
bkreigsr 03-16-2015 04:52 AM
sort of half-assed, but I cut my wires back to the firewalls then just connected the leads in a loop (one to the other) ...no more warning light.
Bill K
