915 3.2 Carrera clutch adjustment
When adjusting the stop bolt ( 1.2 mm ) and the cable preload ( 1.0 mm ) should I pry the release lever away from the positioner lever ? If I adjust the stop bolt to 1.2 mm then pry the release lever arm away from the positioner lever the gap increases quite allot so the feeler gauge will fall down. Same with the cable preload.
Old 03-16-2015, 03:55 PM
