-   -   Help Recognizing a Plug? (http://forums.pelicanparts.com/porsche-911-technical-forum/856298-help-recognizing-plug.html)
Pstallo 03-16-2015 12:43 PM
I am now beginning to reassemble my car after stripping the interior. Unfortunately, I didn't take a picture of this one. Does anyone know what this wire plugs into? It's a male, two-pin plug with a blue wire going to each pin.
It travels under a metal tie down with the wire that connects to the driver's seat. For the life of me, I can't find anything that it plugs into.
http://forums.pelicanparts.com/uploa...1426534857.jpg
CCM911 03-16-2015 12:48 PM
Check your seatbelts.
Pstallo 03-16-2015 01:30 PM
That's what I thought at first, but the seatbelt wire is two-pronged male also and I've located the connector for it...it's the other wire that is under the metal clip with this one.
john walker's workshop 03-16-2015 03:21 PM
Looks like one inside the heat control unit over the e/brake.
Pstallo 03-16-2015 04:00 PM
Maybe it IS to the heater controller...that would make sense.
I attached the wide cable coming out of the heater control box that goes into the transmission coupler housing.
I bet there's a spot up inside it that it attached to that I just couldn't see
