-   -   SC cam upgrades -- spec comparisons (http://forums.pelicanparts.com/porsche-911-technical-forum/8563-sc-cam-upgrades-spec-comparisons.html)
hilandscott 09-26-2001 02:37 PM
I have tried to provide a measure of the difference of the changes of the aftermarket grinds compared to the stock:
________Lift____________Duration (*)
Cam_____Intake__Exhaust_Intake__Exhaust
20/21___0.485___0.452___238_____226
964_____0.464___0.426___236_____226
SC _____0.455___0.402___229_____220
________% Difference
20/21___7_______12______4_______3
964_____2________6______3_______3
I know that the 20/21 web cam is a favorite, and it is more aggressive that the 964 grind. Given that the intake duration is quite close, 236 vs 236 deg, that seems a considerable difference in intake lift. Can this be translated as: for roughly the same amount of duration, the 20/21 grind is snapping the intake valve that much more travel, possibly leading to earlier valve train failure? On the intake side, the ratio of the difference is > 3:1 (.03" total), whereas on the exhaust side it is a closer 2:1.
I haven't seen the gains in HP/torque between the cams, with the proper free-flowing exhaust header/muffler combination of course, but I am curious what benefits folks are getting from the web cams compared with the durability of their valve trains. Is driveability really okay, including low-end response, with the 20/21 web cam grind?
Thanks, John
(*) Data are from Web cams, and B. Anderson's specs are slightly different.
'78 911 SC 3.0
[This message has been edited by hilandscott (edited 09-26-2001).]
Early_S_Man 09-26-2001 02:49 PM
I doubt very seriously that you have anything to worry about in the valve train at the low revs SC engines turn. Take a look at the specs for the SC RS engine in BA's book if you want to see what your valve train is capable of!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
