-   -   how chicken soup solved my engine repair headache (http://forums.pelicanparts.com/porsche-911-technical-forum/856642-how-chicken-soup-solved-my-engine-repair-headache.html)
theiceman 03-18-2015 02:00 PM
The Problem ... like so many others i am in the middle of repairing broken head studs on my SC. I cleaned it as well as i could before pulling the thing apart .. once all apart though and the cylinders slid off and the broken studs removed there is still a lot of grime around the area.
The real problem is how to stop any of that grime falling into the engine while cleaning it .. i have seen guys use rags and cups and all kinds .. but nothing really water proofs it so you can clean with confidence...
Soooo......
I was having my chicken soup for lunch and it dawned on me .. my chicken soup container was strangely enough the same size as the spigot on my 3 litre.. I also just happened to have some inch thick closed cell foam on my table from something i unpacked earlier . I am sure that stuff is available cheap at the craft store..
So i drew a circle on the foam , used a knife to cut it out. I then put a ziploc bag over the rods .. , then i cut a slit in my foam disk to slide over the rod . The foam disk had to be compressed to fit into the spigot which was great ... voila . i now have a water and grime proof spigot hole. I used my cumin spice lid for the oil return tubes and just rough guessed the oil cooler holes .. now i can scrub away ..
took a total of 10 minutes to do all of them ..
just thought i would pass this tip along ..
http://forums.pelicanparts.com/uploa...1426715783.jpg
http://forums.pelicanparts.com/uploa...1426715801.jpg
http://forums.pelicanparts.com/uploa...1426715833.jpg
http://forums.pelicanparts.com/uploa...1426715851.jpg
Quicksilver 03-18-2015 02:08 PM
That is actually a truly great idea!
I'll be eating some soup here pretty soon it seems. :)
82 SC 03-19-2015 03:34 AM
Love home made remedy's for car problems, kind of like chicken soup :)
Lapkritis 03-19-2015 04:10 AM
Pretty cool idea. Combine with a cup over the top and your rod end would stay clean too. :)
Lapkritis 03-19-2015 04:11 AM
Ah, didn't see the baggie. Clever!
billybek 03-19-2015 04:24 AM
Great idea!
82 SC 03-19-2015 05:31 AM
Still nothing can keep out a stink bug! I find those little buggers everywhere! But this is at least a good start. :)
poorsha 03-19-2015 05:58 AM
Now that's using your noodle :)
sugarwood 03-19-2015 07:00 AM
Do people normally just stuff rags into the cylinders?
wayner 03-19-2015 08:37 AM
At first glance I thought you filled your crank case with soapy water to clean it out!
NY65912 03-19-2015 09:13 AM
Perfect!
rusnak 03-19-2015 10:21 AM
Hey, I have to try that!
Cumin spice with chunky chicken noodle!!!
bike2ride95 03-19-2015 01:28 PM
Who said "a mind is a terrible thing to waste"??
very clever ;)
