1979 930 @outlaw3.4
MZ3 SBC's Avatar
Trim moulding kit from Sierra Madre
Anyone use this kit and found the windshield, rear window and 1/4 glass trim to be acceptable or totally unacceptable?
I am not sure if I was sent the wrong parts they are soo tight. They are clearly aftermarket and not Genuine.
The hole kit sold for 1000...included about every rubber trim piece on the car.
I am not sure if I should try again or send it back and pay more for the Genuine. The 1/4 glass is so tight I cant get the metal trim in ..
Old 03-22-2015, 04:04 PM
Not Royce
Royze's Avatar
i bought the same aftermarket and the rubber quality is very hard to work with, but it can be done
keep trying. the quarter window was the most time consuming.
for the metal trim, I used wd40 and lubed the grove for it then it was easier to install.
make sure that your working in a warm area to keep the rubber supple, otherwise it will be even more difficult to install.
Pistache: 1984 911 backdate
@RWB_Royze on IG www.instagram.com/rwb_royze
RWB Japan/Middle-East representative
Old 03-22-2015, 04:17 PM
