^^^ +1.
Also my OEM air compressor to fill a slow leaking flat. I also have a back up $25 from Pepboys in the garage. It saved me a tow truck call. |
Wow!
It is always unpleasant to have such a thing happen. Makes a guy mad, especially when the result of stupidity or carelessness. But consider it another way. This is just a thin piece of sheet metal lightly attached along the lower edge of the car. It could be easily removed and straightened by hand. Being textured the way it is, it wouldn't have to be arrow straight to look straight. Probably wouldn't even require repaint. Not a very noticeable area unless you put your camera down there at the curb. I could (and have) fix this myself in an hour. The oil line does not really look damaged, maybe scraped and just a little flattened at the bottom. Certainly not enough to cause a real problem. This sort of stuff happens. Its life. You could turn too sharp out of a drive and do the same. You wish it didn't happen, but it does. Probably got the young kid in the shop fired. Just added an infinitesimally small amount to the overall pool of insurance claims, causing us all to pay a tiny fraction more. Reputation? Gee, I wonder why the other 99% of the world thinks Porsche drivers are prima donnas (or worse)! How about that repair shop milking this for $2500! I guess I just see things differently. No doubt I'll get plenty of hate mail from this bunch. |
Uh oh here we go
If you live around Los Angeles you might want to check out Wheel Enhancement.
They know what's up, and they take great care of you. |
I remove the wheels, put them into my station wagon, and drive them over.
I was fired as a customer when I complained to the Les Schwab shop. Eff them from now on. |
I only bring my car to shops I already know have knowledge about my car.
It's one thing to wreck it yourself, it's another to have someone else do it for you. |
You should also have a soft lug socket if you have nice lug nuts.
I use a thick zip lock bag or the like between socket and nut.
Can't believe some of these lifting nightmares. I had to rack an Audi R8 once. I wasn't about to GUESS at where the lift points were at. |
I hate to keep rubbing it in but one of the first things you read on forums when you start researching the air cooled cars is crushed oil lines due to bad lifting. I would never take my car to a tire place, just take the wheels.
And you should have let the shop pay. Your insurance is just going to jack up your rates. They will get that $2500 out of you eventually. |
Either way it'll be a subrogated claim so the shop will be paying. And as a comp claim, it shouldn't affect my rates - at least it hasn't in the past. |
| All times are GMT -8. The time now is 05:49 PM. |
