-   -   MAF readings - non linear (http://forums.pelicanparts.com/porsche-911-technical-forum/857571-maf-readings-non-linear.html)
AMSRoadRunner 03-24-2015 06:06 PM
1986 911 3.2 - no cat - is running like crap. dies at lights, (intermittently) surges from low rpm acceleration (intermittently) seems like it is running hot (but oil temp is ok)
I became suspicious of the MAF. After testing I am almost more confused. The ohm meter is always getting a reading but the readings seem like they are oscillating.
Temp side checked out perfectly.
Any suggestions?
Thanks!
Andrew
Tippy 03-24-2015 06:13 PM
I didn't know '73 911's had MAF's.
Elombard 03-24-2015 06:31 PM
I assume you are talking about the 86? Have you seen the deal on the wear groove on the circuit board? You have to bend the sweep arm to a fresh spot? Might be worth popping the cover off to see if it looks like its worn through. There is some information posted about the procedure and details if you search.
Quicksilver 03-24-2015 08:55 PM
Technical whiny bit: The 3.2 doesn't have a Mass Airflow Sensor. It has a "barn door" Air Flow Sensor...
The air flow sensor isn't doing anything at idle. When the idle switch is contacted it is all on the idle control valve to meter air. You can test the switch easy enough to be sure the DME knows to go to the idle circuit. You can also see if the throttle is releasing enough that the switch is engaged. There are a number of threads on testing the idle control valve you can search on.
But ...
Lots of things to test but I'm suspicious of a vacuum leak in the intake gaskets. Check that the allen bolts are torqued to 18 ft/lbs. Even if it is torqued correctly it still could be cracked gaskets.
Easy test is to get an IR thermometer, put the car up on jack stands, start the engine while cold and after 15 seconds or so get the temps of the various exhaust ports. They should be pretty equal.
If there are cold ports you know that something isn't burning there. A misfiring plugs and bad injectors could also show up as a cold port.
ischmitz 03-24-2015 09:18 PM
Go here Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com Very good procedure involving a 9V battery to test the AFM. The Ohmmeter is not using enough current to get reliable readings. Once the test with the 9V battery shows flat spots follow instructions on how to try and fix that by:
- Adding a wire to improve the contact between shaft and wiper
- offset wiper position on thick film resistor to address wear on resistive track
Ingo
NY65912 03-25-2015 02:32 AM
I sent my AFM to Bavarian Restoration, they provide a data sheet of the refurbished unit. THe engine is very happy and linear in acceleration and idle beautifully.
BTW, I also sent my DME to Ingo (Ischmitz) to be evaluated and the necessary repairs performed as needed. Although the car ran very well prior to this work, Ingo found, under microscopic imaging, potential fissures developing in the solder joints which could lead to intermittent conection problems.
As our cars are approaching 30-35 years of age, I thought I would be proactive in heading off any potential problems down the road.
Smoove1010 03-25-2015 05:45 AM
Bumpy idle, acceleration flat-spots, hesitation, idle hunting - these are all popular topics on the forum, and there are many posts. They seem to fall into two categories - vacuum leak troubleshooting and AFM troubleshooting, though the posts go off on many related (and sometimes pertinent) tangents. Here are some threads that I found to be valuable.
Vacuum Leaks:
http://forums.pelicanparts.com/porsche-911-technical-forum/435952-vacuum-leak-you-probably-didnt-ever-think.html
http://forums.pelicanparts.com/porsche-911-technical-forum/455794-vacuum-leak-check-your-brake-booster-line.html
http://forums.pelicanparts.com/porsche-911-technical-forum/786032-another-vacuum-leak-question.html#post7796156
http://forums.pelicanparts.com/porsche-911-technical-forum/614071-stop-smokin-cure-3-2-a.html
AFM, AFR & Idle Adjustments
http://forums.pelicanparts.com/porsche-911-technical-forum/250438-idle-bounce-6.html
http://forums.pelicanparts.com/porsche-911-technical-forum/511893-1986-911-idle-surge.html
http://forums.pelicanparts.com/porsche-911-technical-forum/82651-euro-3-2-air-fuel-mixture.html#post558130
It might be worthwhile to search for threads on the idle control valve and idle switch - these are two of the basics that are very easy to test.
Here's how I solved similar problems on my bucking Carrera: http://forums.pelicanparts.com/porsche-911-technical-forum/835870-afm-mixture-am-i-lean.html
Good luck!
GK
Quicksilver 03-25-2015 06:49 AM
^ +1 ^
Great post Smoove1010! "Test, Test, and when done TEST!" (I hate seeing people throwing parts blindly at problems.)
When I had my "Rubber Explosion®" incident I discovered more then one hose with large cracks in it behind the throttle body. There are a lot of hoses and swaged fittings back there hardening over time!
WYDBODY1986 03-25-2015 08:31 AM
Where can you hook up a Vacuum Gauge to check for a leak and what readings would you expect to see if you had one? 86 911 like the OP
Tippy 03-25-2015 08:47 AM
86 I see. Wasn't there when I was being facetious. 😜
Elombard 03-25-2015 08:57 AM
^I figured he must of changed his sig :-) I was thinking "What does Tippy know?" Is there a story here....hmmmm
AMSRoadRunner 03-27-2015 02:52 PM
Thanks for all the helpful leads guys!!
Update:
I tested the MAF as per:
then I had a beer and tested it again with the same results. Voltage bounces all over the place and drops off when wide open. :(
Not looking good for my MAF.
Going to give Bavarian Restoration a call in the AM. I feel like that is my best bet. (I know, I know perhaps not the best place to talk about my feelings.)
Andrew
Hil911 03-28-2015 03:48 AM
I apologise if this is rubbish, but I remember testing the barndoor flow meter in either my Toyota MR2 or my GTiR and it does indeed have an oscillating signal and that is correct.
In those cars the signal is not supposed to be linear.
