San Diego, CA
77911s Tire Size
What is the original tire size for a 77 911 S? I am getting conflicting information from Tire Rack and Discount Tire (aka Americas Tire Co.).
Tire Rack: 185-70-15 Discount: 215-60-15 I just purchased the car and looks to have the original wheels (6") but came with a pair of wider matching 7" wheels which I thing I will use if they are not too wide for the narrow early style body. . From searches here on the forum, I see that many are running 205-65-15 in the front with 225-60-15 in the rear. I assume the rears have wider wheels too in these applications. If the Discount Tire recommendation is incorrect for an original size, it seems to be a good choice if I were to use the 6 inch wheels all around. Or not ??? Thanks! |
I found this online:
![]() 1977 911 S Targa (911) | Specs | Excellence Quote:
And found this in Pelican I'm working on a narrowbody 2.7 s '75. size tires for a 2.7 ?????? Quote:
Tyres & sizes on 8" rears on narrow body - help please Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 03-27-2015 at 08:17 AM.. |
76 911S Targa
My engine lid sticker says 185/70/15 which I think was standard for the mid year cars. I am running 205/60/15 since the 185/70/15 size is hard to find from most tire manufacturers anymore, Toyo Eclipse if that matters. I would not mind 185/70/15 simply because it looks more period original than what I have but I am not willing to pay extra for the rare tire size.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
This, fixed it for you
Lucky owner of a couple of 911’s and a 924 |
San Diego, CA
Mine don't.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
My 1973 came from 185/70-15 or 165-15's from the factory. Until I got some 16" Fuchs, I used 205/60-15 with no issues. FWIW, they were Toyo H-4's.
A very close fit in a current tire is a 195-65-15.
No rub even on a lowered car and the speedometer is accurate within one or two MPH depending on speed. I have a 7mm spacer in the rear on the 77. ![]()
Nice stance, if it's not in the proper stance thread it should be.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
76 911S Targa
No rubbing with 205/60/15. Not even close. The PO had 215/60/15 in the rear and those did not rub either.
