-   -   Fog light switch terminal ID (http://forums.pelicanparts.com/porsche-911-technical-forum/858106-fog-light-switch-terminal-id.html)
Bob Harriman 03-28-2015 03:52 PM
My 68 switch has terminals 1, 2, 3 and R as well as a bulb terminal. Which one is N, NR, and 58? My Kroon fog light harness is using a different switch in their instruction diagram.
http://i1296.photobucket.com/albums/...pspvsgioi7.jpg
http://i1296.photobucket.com/albums/...pspyfwxhzh.jpg
timmy2 03-29-2015 01:25 AM
Show the end of the switch with all terminals visible. Can you detect any letters at the terminals?
Should be more than 3 terminals, which is all that is visible, and one is for the lamp.
With a meter you can detect which terminal is which.
Show a photo of the new harness as well.
gerakroo 03-29-2015 03:41 AM
Foglight switch
Hi Bob,
Just send you an explanation by email.
Regards, Gerard.
gerakroo 03-29-2015 03:44 AM
And here's a picture Dennis...
http://forums.pelicanparts.com/uploa...1427625839.jpg
timmy2 03-29-2015 01:12 PM
Do you have the original '68 style relay (rectangular) and wiring installed?
My guess is you may need to follow the '70 and later style switch wiring to work with the later fog light harness Gerald posted a photo of.
http://tapatalk.imageshack.com/v2/15...e23aaf3d69.jpg
Donzenac 01-09-2018 06:32 AM
Hi Bob
Did you finally found an answer to your problem ?
I have exactly the same problem
