-   -   ENGINE DROP: Need Some Help/Pointers in ATTLEBORO/Prov area (http://forums.pelicanparts.com/porsche-911-technical-forum/858397-engine-drop-need-some-help-pointers-attleboro-prov-area.html)
seanratpel 03-30-2015 02:44 PM
Planning on a drop in the near future (Probably at end of summer, trying to get everything lined up etc) and could use a helping hand (Very leery of tranny dis-connect and re-connections comfortable with everything else mostly.
Also: Be looking to rent/borrow engine stand/yoke too, let me know, much appreciated.
Ferrariguyma 03-30-2015 02:48 PM
Attleboro here
PM me your contact information. I have a few friends in the area who I can probably get to help as well.
seanratpel 03-30-2015 03:16 PM
ferrariguy - pm on the way
lsf911 03-30-2015 06:24 PM
I have never done an engine drop but am willing to give you a hand if you need the help. I am about an hour drive from you. Just let me know.
seanratpel 03-30-2015 06:58 PM
LOU, I appreciate the offer- Where in mass are you? I'll see what happens the closer I get. Definitely could use a second set of hands though. sean
carrerarsr65 03-30-2015 11:05 PM
l
I live in Agawam ma just did a engine /tranny drop piece of cake 4 bolts undo shift coupler throttle clutch cable some misc hose done http://forums.pelicanparts.com/uploa...1427781898.jpg
http://forums.pelicanparts.com/uploa...1427781943.jpg
seanratpel 03-31-2015 05:14 AM
CARRERASR: You make it sound so easy, Feel like I'm already starting to hyperventilate. My biggest drawback is I'm in an outside storage/tent space its big 20x20 but no cement floor which is a problem. Damn that head stud!!!!!
lsf911 03-31-2015 05:15 AM
Sean,
I am located in Chelmsford. Just let me know if you need a hand when the time comes. I too have an 83 sc.
We can exchange info via pm.
reachme 03-31-2015 05:59 AM
I'm about 1/2 hour away and dropped engine last spring.
Sounds like you will have a lot of hands available
One good thing about living in an area with crappy weather, our maintenance season is much longer
Alex973 03-31-2015 07:40 AM
ck the host here there is how to drop engine
it is easy and fun, try timing yourself the second
time around you can do it in 45 min, given you have a lift
good luck
carrerarsr65 03-31-2015 05:08 PM
safetyfirst
try to get 2 sheets of 4x8 plywood, you heed to get the back of the car up about 34 inches at thr rear reflector and take off the rear bumper gives better clearance http://forums.pelicanparts.com/uploa...1427846855.jpg
run jack stands on inner torsion tube
